Old 03-04-2011, 06:47 AM
melody nelson melody nelson is offline
Default Plug-Ins Load Every Time PT8 is Opened
I've been using Pro Tools 8 for about a year now and never had this problem until I had my computer wiped and restored to factory settings by Staples Business Depot, where it was under warranty.
I've installed Pro Tools 8 and updated to 8.0.4 (which I hadn't done before, I was only running 8.0.1). However, every time I turn on my computer (I'm using Windows Vista) and open Pro Tools, it re-loads the plug-ins, taking 4-6 minutes. If I close PT and reopen it without shutting the computer off, it loads quickly and as it used to. It had always loaded extremely fast before, but since coming back from the tech there seems to be a problem.
Once the program is open there are no problems, everything works and runs fine.
Thanks!
Also, I read somewhere that Quicktime helps with this - I've updated it to the latest version and still no luck.
Old 03-04-2011, 08:27 AM
jmitchell1532 jmitchell1532 is offline
Default Re: Plug-Ins Load Every Time PT8 is Opened
Are you talking about when you boot PT, the plug-in load times are high during the splash screen? I'm pretty sure that depending on how many/what kind of plugs you have, (Waves usually takes a bit to load) it is a normal occurance.
Old 03-04-2011, 08:41 AM
TCM's Avatar
TCM TCM is offline
Originally Posted by jmitchell1532 View Post
.... it is a normal occurrence.
Yep.
002R BLA mod and Mbox mini 2, PT 11.3.2,
HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive
Old 03-04-2011, 08:44 AM
Benoni's Avatar
Benoni Benoni is offline
Originally Posted by TCM View Post
Yep.
Double Yep.
But 4 -6 minutes is crazy.
Are you running old plug ins? Old plugs, especially Waves will add a couple minutes to your start up, but I've never seen 6 full minutes. Have you timed this out, or is it an estimate?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-04-2011, 09:37 AM
I just timed this and it took 4:46 to open the first time, so it's really closer to 5 minutes. I'm just using the default plug-ins. Before, any time I opened Pro Tools, it was completely up and running within half a minute, so it's unusual for me to wait now. Am I just gonna have to get used to it?
Old 03-04-2011, 11:08 AM
Benoni's Avatar
Well if you had the PC restored to "Factory State" then you probably need to re-do the Optimizations for Vista.
http://avid.custkb.com/avid/app/self...p?DocId=211077
They are pretty much the same as the Windows 7 optimizations.
Avid Windows 7 Optimizations Video Playlist - YouTube
Be sure to run as admin.
and you may want to post a Sandra Report
- Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
CLICK HERE---->Sandra Report<----CLICK HERE
Under SiSoftware Sandra, click on "Download & Buy" to download the FREE Sandra Lite version or purchase other versions.
After installing Sandra, click on the
'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the
DUC.
Help Us Help You
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
First Time opened pro tools 10 error?! applecore3401 macOS 4 10-23-2011 09:31 AM
message reads I/O setup has changed since last time session was opened last time peteor96 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-05-2011 08:29 PM
Slow boot-up time PT 8.0.4cs2 on Win 7 - plug-ins load every time jmac146 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-02-2011 04:49 PM
Why tempo reset each time session opened nortstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-08-2007 03:38 PM
Slow plug-in load time Larstaylor Pro Tools TDM Systems (Mac) 3 03-01-2005 10:05 PM
