  #31
Old 12-11-2019, 11:06 AM
creativecontrol's Avatar
Default Re: Monitor Profile intermittent on S6
I did inquire with NTP and it was not clear why there was additional wait time. It was suspected that the first time the app is launched network communication is waiting to proceed. In successive launches the boot time is quite fast. If I get any more info I will feed it back.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #32
Old 02-17-2020, 09:13 AM
devinemke's Avatar
devinemke devinemke is offline
Jeff,
long delayed launch of DADman 5.3.4.3.
any further word on this from DAD/NTP?
thanks
Devin Emke
Audio Post Production
Saturday Night Live, NBC
  #33
Old 02-23-2020, 11:58 AM
Greetings,
I’ve passed all the data on to NTP in addition to our EUCON team. I’ve repro’d exactly what you’ve described. Hopefully the load time can be improved.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #34
Old 09-24-2020, 11:34 AM
devinemke's Avatar
Jeff,
just now get getting back into my studio after a long absence due to the pandemic. was upgrading all of my software (PT, S6, etc...) and was disappointed to see that DADman is still at version 5.3.4.3 which still has this long delayed launch issue.
thanks
Devin Emke
  #35
Old 09-24-2020, 12:40 PM
Greetings,
There are new versions of DADman in test at Avid currently - so we should have a new public release soon. As a work around in the meantime, if you have WSControl + EuControl both launched you shouldn't see any delay at all. The conditions have been reported and are easily reproducible. I've just inquired with engineering again.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #36
Old 09-24-2020, 12:48 PM
devinemke's Avatar
Jeff,
regarding your work around:
i have WSControl and DADman set to auto launch at startup (via the "Auto-Launch" settings in WSControl). i do not use/need EuControl as i only have an S6 (no other controllers that use EuControl).
i am still seeing this long delay of DADman on startup. i am missing something about your work around?
please advise. thanks.
Devin Emke
  #37
Old 09-24-2020, 12:51 PM
It is possible to add a single Avid Control client to work in conjunction with S6, which requires EuControl to be running simultaneously. Some folks use this for workflows like surround panning or shuttling between markers for example. It is certainly uderstood if you don’t need or want it. I was simply passing on a condition that does in fact mitigate the wait time.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #38
Old 09-24-2020, 01:08 PM
Would you mind logging a case so we can get this issue tied to your account? It would be helpful for me to help get the resolution expedited. Thanks much.
https://avid.secure.force.com/pkb/ar...-Case-Creation
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #39
Old 09-24-2020, 03:00 PM
devinemke's Avatar
Jeff,
i personally do not have an Avid account with support entitlement. i work for NBC. it's their Avid system under their support contract. i will try and reach out to the manager of this Avid account to get a case created.
thanks
Devin Emke
C24 cue/monitor intermittent now failed omoanya ICON & C|24 0 03-26-2013 10:22 PM
Control24 Intermittent Hiss in Monitor Rwave ICON & C|24 0 07-26-2010 07:57 AM
Control Monitor Section STILL Intermittent! a2zproductions ICON & C|24 3 11-07-2008 09:29 AM
Can't monitor record enabled tracks...intermittent gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2005 10:04 AM
Intermittent left monitor dropout Sofine ProControl, Control|24, Command|8 3 01-14-2005 06:34 PM
