Old 01-08-2018, 02:30 AM
ianfleming1992 ianfleming1992 is offline
Default Re: Audio pops and then cuts out - have to restart
Right I've done this but when I put it in the unused folder it doesn't seem to change anything. The plug-in is still usable and doesn't disappear from my project.
Old 01-08-2018, 06:17 AM
Originally Posted by ianfleming1992 View Post
I'm using windows and I'm not entirely sure how to do the same thing.
My apologies as I missed that; Mac guy here.
Jack
QAPLA!
Old 04-25-2020, 04:25 AM
thigohdx thigohdx is offline
I am using Blue cats frequency analyser but I removed it and the issue still occurs. One thing I have noticed is that when the pop happens, one particular bus massively peaks and then does not work after this. It hasn't got any plugins other than a pro tools eq. When i say it doesn't work at all, i mean the volume metre no long moves whereas all the other ones do besides the master track.
Hi there, did you find the solution? Same here!!! Best!
Old 04-28-2020, 10:06 AM
If the plugin still works, then you probably copied it instead of moving it. Since 11 is a 64 bit program, try going to Program Files>Common Files>Avid>Audio>Plugins(ProgramFiles(x86) is the path to 32 bit plugins).
Old 02-16-2021, 12:20 PM
guitrman guitrman is offline
I am having the same issue, pop and then loss of sound during playback or bounce. Did you ever figure out what the problem was?
Clicks/Pops/Distortion, have to restart, TDM weakness? Audioartist Pro Tools TDM Systems (Mac) 9 03-30-2013 02:10 PM
PT LE audio cuts out during playback illiotic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-08-2011 10:50 PM
Audio cuts in & out w/ MBox2 kkinnon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-17-2009 04:45 PM
BTD cuts off the end of the audio. Why? SteveGarman Pro Tools TDM Systems (Mac) 2 05-27-2005 05:03 PM
Audio cuts out! HELP! rossi21 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-26-2005 10:49 PM
