Old 06-20-2011, 08:15 PM
nokiafiji nokiafiji is offline
Default Trilian with PT9
anyone know how to open Trilian in protools 9?
i installed all the disc, properly, but when i open my protools, i cant even find it, anyone know how to launch Trilian, please help, thank you.
Old 06-20-2011, 08:56 PM
bradch00 bradch00 is offline
Default Re: Trilian with PT9
After you have applied any/all updates. I purchased mine last year and there have been a few updates since.
Create a stereo instrument track, at the top of the track in the mix window, insert > instrument > Trilian.
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 06-20-2011, 09:38 PM
danander11 danander11 is offline
Install Trilian to your main drive, and all of the samples/sounds to a secondary drive.
It works just fine with PT9.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 06-20-2011, 09:48 PM
how do i install it in my main drive, which disc is the trilian, there are 5 discs, i installed all of them in my external drive.
Old 06-20-2011, 11:39 PM
That's why it's not working then. The program will be on disk one. Install Trilian to the main drive, then when it asks you where to install the sound files, select a different drive. Spectrasonics offers pretty clear installation instructions..
The prog has to be installed on the main drive for it to work though.
Here I am,
Hobo Shave!
Old 06-21-2011, 06:09 AM
aka21stCentury aka21stCentury is offline
This applies to all the Native-Instruments stuff as well. VIs go to the OS drive (even synth sound presets like Prism (for Kore 2) to the OS drive) only the sample library goes to the second drive (note: ---> NOT a second partition on same drive)...samples must be written to a separate drive (partition it to 200-300 gigs) use the remainder as a BU for session files and audio files.
Never fill a booting OS drive beyond 75%. Audio drives for recording never fill beyond 50%. BU drives you can up to 90% capacity. Use only Oxford chipsets for Firewire/USB-2... eSata (if only) doesn't require a chipset, the connection is straight through if no hardware raid is present.
Old 06-21-2011, 12:08 PM
i did re installed the first disc on my main drive, still cant detect trilian in my pt9, do i have to reinstall everything again?
Old 06-21-2011, 12:31 PM
How are you trying to open Trilian?
Old 06-23-2011, 01:13 AM
open/use it in protools 9
Old 06-23-2011, 05:00 AM
He asked how, not where.
Tell us your procedure for trying to instantiate Trilian for use...
What kind of track do you use, how do you go about setting it up, etc...
Here I am,
Hobo Shave!
Trilian and 11R issues - Please help! Fezzter Eleven Rack 3 03-07-2014 09:26 AM
Help! Problems with Trilian in Pro Tools 10 kb13 Virtual Instruments 3 01-04-2014 04:09 AM
Trilian gliss up Stig Eliassen Virtual Instruments 6 05-24-2011 03:37 AM
Spectrasonics Trilian...WOW!! scar97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 11-18-2009 10:03 PM
Trilian in the house! johnnyv Virtual Instruments 16 11-04-2009 11:39 AM
