Old 01-11-2013, 08:33 PM
Bill Mellow Bill Mellow is offline
Default Re: Windows drivers for digi 002/003
I've just experienced this problem as well on my 003+.
With my buffer set to 64 samples to 512, I hear a glitch on the tracks that are playing back everytime I Quickpunch in and out. The audio that is recorded is completely fine. It is only in the monitoring.
Also when you hit stop on the transport, any track that has a reverb on it, the tail gets chopped for a brief moment then continues to play.
If I increase my buffer to the max 1024, and turn delay comp on, the problem goes away.
BMellow
Bill Mellow
Re-recording Mixer
http://www.imdb.com/name/nm0578138/
Old 01-13-2013, 08:59 AM
bcwiz's Avatar
bcwiz bcwiz is offline
BMellow
Well for me the reverb tails are much better at higher buffer settings and the punch in/out glitch is less but still there. Trouble is who wants to track at 1024. Shouldn't be doing this anyway. The Mbox on the same machine with the same session is fine, what does that tell you.
Brian Campbell
"Air mixes better than any console" Bill Porter
"Humility is mighty important in this business of listening" Bob Olhsson
Old 01-16-2013, 08:45 AM
bcwiz's Avatar
The silence...
Brian Campbell
Old 01-16-2013, 09:01 AM
The glitch is well known and documented. FWIW, when I punch in/out with the keyboard(F12), I don't get it. Using a footswitch almost always gets it.
Old 01-16-2013, 09:33 AM
bcwiz's Avatar
I wish that were the case here, F12, mouse, pre roll, transport buttons, all the same glitch in the playback of other tracks.
Which begs the question, why hasn't it been fixed?
Brian Campbell
  #16
Old 01-18-2013, 09:07 PM
Tracy Lowery Tracy Lowery is offline
PT7
Originally Posted by bcwiz View Post
Punch in/out has a distorted very unprofessional 'glitch' in the audio, like it skips.This is glitching on the playback tracks not the record tracks. The rig records fine this is a monitoring issue.
When the transport is stopped there will very often be a gap then the reverb tail will play.
Often when the transport stops/starts on a transient there will be a short burst of distortion.
See this thread http://duc.avid.com/showthread.php?t=310286 and others going back to PT8.
I went from PT7 to PT10 and that's when this started, same gear.
I have seen it on five completely different 003 rigs.
Finally, I have had this same problem since moving from PT 7.4 To PT 10.32. The gap between the reverb and delay tail...driving me crazy. But it is an intermittent issue that comes and goes with no reason. I have tried to track it down many times. By the way Im on a Digi 003 rack....Whats the latest on this?
Asus Sabertooth x79/I7-3930k/32G GSKILL
  #17
Old 01-18-2013, 09:54 PM
bcwiz's Avatar
Originally Posted by Tracy Lowery View Post
PT7
For me the problem with reverb tails improves at higher buffer settings.
I believe this is related to the punch in/out glitch that disrupts playback tracks, as well as the brief distortion that often occurs when starting or stopping. It's the damn drivers. An Mbox2 behaves better!
Avid appears to be ignoring the problem and show no signs that it will ever get fixed. (piss poor support)
I'm getting close to just dumping the two 003Rs that I have and move on to something else and it's very unlikely to be Avid hardware.
Brian Campbell
  #18
Old 01-22-2013, 09:14 AM
bcwiz's Avatar
crickets...
Brian Campbell
  #19
Old 01-30-2013, 08:57 AM
bcwiz's Avatar
bumpity bump
Brian Campbell
  #20
Old 02-12-2013, 10:47 AM
bcwiz's Avatar
Tech support has duplicated the punch in/out issue and recognized there is a problem, so it remains to be seen how long or if a fix is released. It's been almost two years since the last 002/003 driver release.
Brian Campbell
Is standalone Windows Audio Drivers v8.0.3 compatible with WINDOWS XP 64 ? VonHelvete 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-28-2010 10:01 AM
digi 002 windows vista drivers? babymanuel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-18-2007 07:52 AM
windows XP Pro/Digi 001/Drivers.. Where??? saavadra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-19-2003 02:50 PM
Ok Digi, I now need Windows Mbox drivers Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-19-2002 11:46 AM
Windows 98 drivers MikeA Digidesign Hardware & Software 1 06-01-2000 01:51 PM
