What interface card/rack for LE ?
Hello,
A friend of mine upgraded from Win to MacPro and realised later that it was a PCIe machine. So he had to get ride of his M audio card (only PCI). I just have a simple question really: what interface do one need to use for PT to work ? I can understand that HD require the mix engine on the core cards etc... but how come one need an M audio card to play with Protool M ? How about LE ? Would any sound card do the trick ? I have a MOTU 828 mkII hanging around could he use that one and LE or M ? Thank you, Nils |
Re: What interface card/rack for LE ?
LE requires Digi hardware. M-Powered requires M-Audio. Your MOTU stuff will not work with ProTools.
Even with the hardware you cannot output any channels via the CPU's audio I/O (or any other PCI card etc.). Seems strange doesn't it? Thuggish even?
It could also be that Digi doesn't want the headache of trying to support hardware that isn't under their control.
Is the other low-end hardware out there really that much better than Digi's or M-Audio's? It's all based on the same cheap components isn't it? |
Thanks guys.
I think Digi is smart not to support all these other cards. I don't want to pay the price of maintenance R&D to be honest. However, I also think that it is very uncool to verify what hardware is installed and decide not to work because the soundcard manufacturer isn't home brand. I don't mind using unsupported hardware and live with my issues. But there is a lucky/cheap combination, then why not let it be usable... Bottom line... Digi: you win (again) ! Regards, Nils |
If you were using M-Audio hardware, then you must have the M-powered version of Protools, right?
If so, than just about any M-Audio firewire interface should work.
Larry PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins. |
I think you're right on Digi supporting their own hardware only. I'd draw a comparison to how Apple controls the hardware and software (contributing to Apple's "legendary" usability), where windoze is a free-for-all on the hardware side causing all kinds of driver issues. This has probably contributed to the long roll-out time for Vista as well..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Venue + mix rack + hdx card + pro tools hd native card ? | hart07 | VENUE Live Sound Systems | 2 | 05-23-2012 12:02 PM |
11 Rack vs. 003 Rack as interface when booting Pro Tools ?! | Sir Jamalot | Eleven Rack | 7 | 02-23-2012 03:51 PM |
VENUE D-Show using MADI-Card and FWx-Card in FoH-Rack | Zacha | VENUE Live Sound Systems | 6 | 07-02-2011 07:04 PM |
PTMP - PCIMCIA card interface (aka PC card) anyone else? | Gilliss | Pro Tools M-Powered (Mac) | 5 | 08-19-2007 05:44 AM |
interface vs. pci card? | sykobilly65 | Pro Tools M-Powered (Win) | 0 | 08-18-2006 08:57 PM |
