Too short MIDI notes = No MIDI out
When recording very short staccato MIDI notes they will be "muted" when playing back the sequence. When I look at the MIDI Editor I can see there is a X over the shortest notes as if Pro Tools thinks they are not intended to be played as they were accidentally recorded or something...
Is there a setting for this ?
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Re: Too short MIDI notes = No MIDI out
I think it might be the note is doubled? So another note sitting underneath! I did see this before but was quite a while back now so can't exactly remember. But start there. Chris
i have this since years, have to cancel the x note manually, it's a bug.
there was a post about midi bug un PT but i think was censored, lots of people have this, anyway i notice that switching off and on my axiom49 solve the bug. i notice also this happens when you hit the keys very hard, is not only for staccato notes this problem, do you have a semiwaighted or waighted midi controller and wich model? |
Its more than likely your keyboard is sending out duplicated notes, maybe for aftertouch!! Chris
I don´t think it is duplicate notes. I am pretty sure it is only when I play very short staccato notes...I can grab the note and make it longer in the MIDI editor then it will sound...
I have a heavy action keyboard... Triton Pro X...maybe the hardest keyboard ever built... You have to be a bodybuilder to be able to play fff on it... So for me I can just barely come up to mf at the moment
Midi is played on time but midi notes are early on play back. | steveooo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 09-30-2022 12:17 PM |
Showing MIDI Notes Being Played While in MIDI Editor Window? | ianbee | Pro Tools 10 | 12 | 10-12-2016 06:39 AM |
MIDI Notes Record Short.... | goosefreak | Pro Tools M-Powered (Mac) | 3 | 02-07-2012 06:36 PM |
Moving Very Short MIDI notes | timdiggle | Tips & Tricks | 8 | 04-03-2006 08:31 PM |
Grabber and short midi notes | tld | Pro Tools TDM Systems (Mac) | 6 | 06-07-2000 09:19 AM |
