Old 03-05-2010, 03:16 AM
Karl Engel Karl Engel is offline
Default Select sample rate of audio to import -V7?
On my work's LE system an engineer showed me how to sample-rate convert audio on import - but at home I can't find this option. Pretty sure it was in the Import Audio To Track dialogue. I'm using V7, and am wondering if this was introduced only in a later version.
Specifically I recall there was a box to tick and drop-down menu specifying the sample rate of the audio to be imported.
It was an odd case because the audio had been recorded in a 44.1 session but mistakenly synced to a clock at 48, so it was saved as 44.1 but playing back sounding slow. The engineer specified a sample rate of 48 on import to a session at 44.1 and that fixed it - but I can't find how to do it now.
Old 03-05-2010, 10:59 AM
Top Jimmy's Avatar
Default Re: Select sample rate of audio to import -V7?
On import, uncheck the 'Apply SRC' box and the file will be copied directly over to the new rate without being sample-rate converted.
James Cadwallader
Import session data sample rate conversion also stetches audio? nick133 Windows 1 07-18-2012 10:30 AM
Import Audio - Sample Rate Confusion nhaudio Pro Tools TDM Systems (Mac) 1 07-23-2010 07:47 AM
import audio WITHOUT sample rate converting? wwittman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-21-2009 04:25 PM
Sample rate conversion using import Audio gtole Pro Tools TDM Systems (Mac) 9 03-17-2003 08:14 AM
Audio import sample rate conversion P Oskam Tips & Tricks 0 12-03-2001 07:52 AM
