external drive for playback??
Hello :)
i am thinking what external drive for playback is good with pt801 this came into my mind:WD blue 320GB sata2 7200rpm 16m and:Manhattan Expresscard/34 esata300 would this work out for playback? thanx :) |
Re: external drive for playback??
Are you putting that drive in some kind of case? The case will matter more than the drive(but I recommend the WD Caviar BLACK over the BLUE). The case must have an Oxford chipset for firewire, but any eSATA connection should work just fine. Be forewarned that the eSATA cable connections can be flimsy. If you find locking cables, use them. I had a standard eSATA cable on my external DVD burner and needed to reseat the connections weekly.
yes i have here Icy box External 3.5" HDD enclosure with usb2,firewire 1394a,eSata.
power adapter (100-240V). i think i should be able to use that? i can only fit 2 internal drives in my pc and i was having some DAEerrors all the time and for a whole year i overlooked the obvious witch was my os drive being partioned and the audio playback was on the other partion of the os, hehe talking about not paying attention hehe so many hours and months of frustration. also know couple of people who gave up but not once did i thought about changing to another daw, they might be slow with the fixes and stuff but i have absolute faith in digi. ill go for the caviar black and check those eSatacables with the lock Thanx allot |
Why does Avid recommend external USB over external Firewire for audio drive? | DJ Hellfire | Pro Tools 10 | 10 | 03-29-2012 09:39 PM |
Recording/playback on external drive | remusjacobs | macOS | 2 | 10-09-2011 02:27 PM |
Recording and Playback in external hard drive | brichrath | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 07-09-2010 12:47 PM |
Record/Playback on an external drive | vinyldj69 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-30-2008 07:51 AM |
Playback from external drive problem | kjcoral | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-02-2006 05:53 PM |
