Old 10-06-2004, 07:39 PM
cconley cconley is offline
Default Firmware update/problem for 002 Rack
I just bought a new 002 rack and the first thing I did was upgrade to 6.4
Now when I open Protools I get the following message:
"The Digi 002 Rack has system firmware v1.08r which does not match the
current system firmware version v1.20r. Would you like to download the
current version? Please note, on some computers this may take as long
as 10 minutes."
This is all well and good but for a week now I haven't been able to "connect"
even though my internet connection is perfectly fine
(as exemplified in me posting this message)
I get: "The firware download to Digi 002 was unsuccessful. Please check
connections and try again."
I am forced to deduce that Digidesign just doesn't have this file to be
downloaded. I have searched the website for another link but to no avail.
I know I'm missing something and some help would be
very much appreciated.
Thanks !!!
Old 10-06-2004, 07:43 PM
clutch clutch is offline
Default Re: Firmware update/problem for 002 Rack
I believe the firmware is not downloaded from the internet but from the computer to the unit. It's built into the version of the PT software? (Please - correct me if I'm wrong!)
Try unplugging and replugging your firewire cables, restarting the unit and try it again.
He used to cut the grass...he was a very nice boy...
Old 10-06-2004, 07:57 PM
sleepingtiger sleepingtiger is offline
Hey,
I just went through this when I used a loaner for a few days while my 002 rack unit was being serviced. Clutch's response is right on the money. It's between the software and the hardware, doesn't involve the internet. I had no problem with it. Just clicked "okay" and waited about ten minutes until it was done...
Take care,
Pro Tools Ultimate 2023.9
Dell Precision T7600
64 gigs of RAM
Windows 10 Pro
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
Old 10-06-2004, 08:05 PM
SimpleNatureSpirit SimpleNatureSpirit is offline
The firewire connection is considered a network connection by the system. You might need to make sure you are using the same FW port as when you loaded the software. Try reinstalling your drivers and just follow through with the firmaware upgrade. Eventually your system will recognize all the FW ports as valid. Also be sure not to let your system load the Digi drivers. These must come from the Digi Setup program.
Share the gift gifted to you
Digi-003 Rack LE 7.4 firmware update problem jmaulz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-21-2008 05:31 PM
Firmware Update HELP. My 003 Rack will not update Firmware. New003RackUser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-17-2007 09:01 AM
002 Rack Bad Firmware Update abstech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-27-2006 08:50 AM
002 Rack Bad Firmware Update abstech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-13-2006 10:37 AM
002 rack firmware update killed my rack and OS X bandgear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 11-01-2003 08:25 PM
