Old 01-18-2010, 08:19 AM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Default Is it better to use a Trim plugin or Gain plugin?
I'm just curious about which one would be more beneficial. I don't want to loose any quality in my audio files. I just found the trim plug in and I find it easier to use than the AudioSuite gain plugin. I also use Blue Cats RTAS plugin for use on some tracks. Again, which would benefit me more: The Trim or the Gain Plugin.
Thanks for your patience.
Lets also pray for the people of Haiti.
Disk
Old 01-18-2010, 08:24 AM
EGS's Avatar
EGS EGS is offline
Default Re: Is it better to use a Trim plugin or Gain plugin?
They both have their uses. What exactly are you trying to accomplish?
Click for audio/video demo
Click for resume
paulreed paulreed is offline
automate your volume instead, much more "undoable". If you do use the audiosuite, I would either save each setting in your session files or put the setting in your notes on each track so you can go back if needed.
I just automate.
back up, back up, back up
Old 01-18-2010, 08:44 AM
Oh, don't mentioned back up. Had my mishap a couple of months ago.
What I am trying to accomplish is to have the best quality of sound for mix down for Mastering. I have been reading up on Bob Katz and his view on mixing before Mastering. Some of my recording levels I think are too hot and when bringing down my faders to achieve the right levels, some of my faders end up pretty low. I know it's digital. It's taken me some years of research to understand about recording at the right levels.
I have an iMac and I'm trying to reserve as much power as possible. I rarely use automation even though I want to especially when mixing down. Like the old days when you invite all your friends over to grab a fader. I should try it out on a tune I don't like so much. I'll have to read up on that paulreed. Would you happened to know of somewhere I can download some reading material on that?
Thank you.
Disk
Old 01-18-2010, 11:40 AM
Top Jimmy's Avatar
OK, Audiosuite processing reduces the source signal/quantization error ratio when gaining down. It has to fit within the 16 or 24 bit file depth.
RTAS trim maintains the original source signal/quantization error ratio, it only scales is down within the 32-bit framework.
Realistically speaking though, it all depends on whether you want to apply the gain change destructively or non-destructively. Do you want to archive the original too loud tracks, or the gain changed tracks?
If it were me, I would not Audiosuite gain 16-bit files, but I would Audiosuite 24-bit ones.
James Cadwallader
Old 01-19-2010, 02:43 PM
Thanks Top Jimmy.
Is the Clip Gain the same as a Trim Plugin? SpinningDisk Pro Tools 11 14 09-15-2022 05:07 PM
trim plugin question masterduk Pro Tools TDM Systems (Mac) 18 09-21-2009 05:26 PM
Trim Plugin torquemada 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-29-2006 03:42 PM
where is the Trim plugin? Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-05-2002 07:26 AM
Trim Plugin delay geosounds Tips & Tricks 1 02-13-2002 07:54 AM
