Recall Track Preset on existing tracks
I have a lil bug me thinks..... when creating new tracks from presets. if you go through the Track>New dialog all is ok, but if you.... well "I" as I don't know if others have the same issue. But if you right click on the track name in either Mix or Edit windows and go via Recall track Preset>Avid or User and select anything there you get lil chug chug but no joy.
PT 2018.7 on MBP listed below.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's Last edited by jeffro; 08-15-2018 at 09:02 PM. Reason: Moved to its own thread for visibility. |
Re: Recall Track Preset on existing tracks
Cannot repro with 2018.7 on macOS 10.13.3 (iMac in my sig). Has this ever worked for you? Anyone else seeing this?
it is/was the first time I tried/attempted to create a track via the Recall Track Preset method I outlined, picked up as I go through the process of leaning PT
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
Oooops on further investigation I may have misunderstood what was to actually happen. I was expecting the Recall Track Preset method was to create a new track when actually as the menu item suggests it loads the preset onto the selected track. Yet the concept described in the reference manual seemed to suggest a new track would be created.... or I misunderstood the text.
Apologies, and Mods may want to delete this thread.
Recall track preset | colliderman | Pro Tools 2018 | 0 | 03-17-2018 06:20 AM |
Import tracks and move them to an existing track | Downtown_BE | macOS | 2 | 08-30-2012 11:42 AM |
Edit to mix from existing tracks | JCHeinritz | Pro Tools 10 | 9 | 01-23-2012 02:48 PM |
Trouble record armed track jamming to playing existing tracks? | Gravy | macOS | 5 | 11-29-2011 02:58 AM |
Is there a shortcut for adding or deleting tracks from existing track groups? | melodymanpop | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-13-2001 11:31 PM |
