Old 10-08-2020, 02:42 PM
A1's Avatar
A1 A1 is offline
Default iPad with Avid Control not showing up in EuControl on Catalina
Trying to setup Dock and Avid Control on iPadPro frustrations:
Dock works fine but Avid Control is dimmed out... showing "Not Connected"
EuControl is the latest version (I guess since I just downloaded it): 20.6.1.3
App Version shows: 20.6.0.1 (which I just downloaded as well) on iPad Pro OS 14.0.1.
PT Version: 20.9.1.123
I read that Control app and the EuControl are supposed to be the same version but where do I get the downloads to be the same?
Dock is connected vie Ethernet directly to the computer and the iPad is connected to the Dock via a USB cable.
Any Tips to resolve the issue?
Last edited by jeffro; 10-14-2020 at 05:34 PM. Reason: New thread with posts consolidated.
Old 10-08-2020, 10:05 PM
A1's Avatar
A1 A1 is offline
Default Re: iPadOS14
I'm not having any luck on iPadOS 14.0.1 and Eucon 20.6.1.3
PT Dock works fine but the Control doesn't even show up in EUControl
Settings.
Any Tips?
Old 10-08-2020, 10:45 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Settings.
Any Tips?
I’ve had this issue. Make sure WiFi is turned on, both the iPad and the computer... and on the same network. Even if the iPad is hard-wired directly to the computer.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 10-12-2020, 04:04 PM
A1's Avatar
A1 A1 is offline
Yes it is. Still no go.
Old 10-12-2020, 05:22 PM
A1's Avatar
A1 A1 is offline
Default Re: Avid Control app does not connect
Still the same issue as I've posted elsewhere with Dock & Control
No luck on iPadOS 14.0.1 with the latest version Control App and Eucon 20.6.1.3
Settings.
Same wi-fi connection etc... followed many of the troubleshooting steps posted around here without any luck.
Frustrating! Anyone?
Old 10-14-2020, 02:52 AM
joeshepard joeshepard is offline
I had a similar thing happen to me. I had the latest version of Eucontrol and the Control App but it wouldn't work. I deleted the Control iPad app and re-downloaded it from the App Store and it then showed up in the Eucon device list and I was able to select it and it connected.
MacBook 16" Pro Max 2TB 64GB
Ventura 13.6
Pro Tools Ultimate 2023.12 (Native)
Logic Pro 10.7.9
Eucon 2023.12
2 Artist Mixes
Avid Control on an iPad
Soundflow & Streamdeck XL
UA Apollo|x|16, UA Apollo Twin|x, UA TB Octo Satellite
Old 10-14-2020, 03:48 PM
A1's Avatar
A1 A1 is offline
Thanks Joe, but still no go.
Old 10-14-2020, 05:52 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: iPad with Avid Control not showing up in EuControl on Catalina
[Consolidated posts a bit since they were spread across a few threads]
I have a similar setup (but with HD Native Thunderbolt on an iMac) - iPad Pro & Galaxy Tab A with S1 & Dock. I switch my controllers between 2 Macs and that works fine - only probs have been when versions get out of sync (I change setups a lot to test different things) or if my iPad switches over to another network.
Can start a support case to get more detailed system info if needed...
linkedin
Does PT First support Avid Control iPad app? atkeyboards Pro Tools | Intro Discussion 4 02-13-2021 03:17 PM
S3 + iPad Running Avid Control priorytools Avid S1, S3, Dock and Control App 0 06-07-2020 05:13 AM
EuControl v3.7.0/ Pro Tools | Control on iPad Pro doesn't work... Smithtrax Avid S1, S3, Dock and Control App 47 03-10-2018 07:48 PM
EuControl/Workstation 3.3 & Pro Tools | Control iPad app now available! Kyle Splittgerber Avid S1, S3, Dock and Control App 0 08-06-2015 02:59 PM
