Can I upgrade MacOSX 10.10.5?
I'm on 10.10.5 because I have Pro Tools 11 and I'm afraid to upgrade.
I'm running into issues where I can't use other apps because they require newer versions of MacOS. I really don't want to buy Pro Tools again. What are my options?
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory. |
Re: Can I upgrade MacOSX 10.10.5?
You could, if your system drive is big enough, split it into two partitions and put a newer OSX on the other partition which is what I did. So I have one partition with OSX 10.10.5 and the other with OSX 10.12.6 and have the latter partition set as my boot-up partition. Remember that by holding down the option on the computer keyboard you can select what partition to boot into or that can also be set in OSX preferences. What exact version of PT11 do you have? Oops - just saw you have PT11.3.1; I don't know if this will work with that version. If you need further help with that PM me and we'll discuss. |
Hmm. PT says I'm up to date. Maybe people had to pay to go from .1 to .2?
I'll look into the partitioning. I don't like the idea, but it might be my only option. Thanks for the info.
Like I said - drop me a PM or email and we'll talk further. The partitioning is easy using OSX disk utility. Done right it won't wipe out existing programs and data. The only downside if you want to do it right without errors is having to install from clean all your programs. Using OSX Migration Assistant (aka Assassin) is iffy at best to bring your stuff over into the new partition. I'll not take up space explaining what I went through right now but am willing to share my travails if so needed. Your bigger problem is going to be getting a version of OSX 10.12.6 but even that isn't unsurmountable. Take a look at Amazon for a solution. They have some thumb drives and dvd's with OSX on them. |
Ok, thanks. I'm going to try to hold off as long as I can. I'll let you know if I pursue the partitioning route. Thanks again!
PT 10.3.4 and MacOSX 10.6.8 | rrongman | macOS | 3 | 04-08-2013 09:37 AM |
Can i keep both PT 7.4.2 and DP 6 on the same MacOSX 10.5.3 ?? | petja | Pro Tools TDM Systems (Mac) | 2 | 04-27-2009 02:03 PM |
003+Macosx | neilcash05 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-18-2008 06:15 AM |
Why MacOSX? | Kenny Gioia | Pro Tools TDM Systems (Mac) | 26 | 01-16-2002 04:06 PM |
MacOSX | jduffas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 10-26-2001 12:24 AM |
