Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 09-28-2020, 12:42 PM
josoro505 josoro505 is offline
Default Pro Tools error in booting up
Says:
Could not complete your request because Assertion in "d:\ code\ scm\ protools\ release\ 2020\ r1\ protools\ aae\ source\ aax\ cficaaxwidget.cpp", line 994.
(Use the Copy button to copy this message to the clipboard.).
Now what?
Old 09-28-2020, 01:04 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Pro Tools error in booting up
Originally Posted by josoro505 View Post
Says:
Now what?
At what point do you get the the error? If it's when plugins are loading, look at the last plugin trying to load before you get the error - that could be the problem.
What troubleshooting have you done so far? Make sure you do everything listed here: Help Us Help You
Have you tried trashing Preferences?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.9
Old 09-28-2020, 07:18 PM
In addition to above, do you have an interface? Have you installed a driver for the interface? Have you tried holding the N key while Pro Tools opens(which SHOULD take you directly to the hardware setup window where you select the "audio Engine", which is the hardware you are using for input and output). Read the thread that cwsand linked to(Help Us Help You) and come back with details(right now, we all know exactly nothing about your setup)
Old 09-28-2020, 07:25 PM
JFreak's Avatar
JFreak JFreak is online now
First of all, are you using a supported OS/PT combination?
Janne
Old 09-29-2020, 05:08 PM
Sucks when there is SO much info available yet one sees this at the top of the page:
Avid Knowledge Base
Compatibility & Upgrade Information for Pro Tools on Windows
Pro Tools Compatibility Grids with Pro Tools Update and Upgrade Information
Last Updated : April 6, 2018
4-06-18?
Nothing newer?
I did something and got PT to load; created a session and started messing around (I'm a fan of ACID Pro circa 2002)---there's no PAUSE button! So I searched FaQs and there are NO MATCHES for "pause."
Google has on file Qs about this same issue, dating back to 2014...what, no fix?
Crazy
Old 09-29-2020, 05:46 PM
Pause is not really an issue for most folks. They have worked out how to use "timeline insertion follows playback". Or actually want to not do that and just use timeline markers without the pause like behavior. If that's new to you, search for it in the Pro Tools Reference Guide.
Old 09-30-2020, 01:05 AM
cwsand's Avatar
Avid Knowledge Base
4-06-18?
Nothing newer?
Hi, Not sure where you're seeing that, but here's a current article:
Pro Tools Operating System Compatibility Chart
What did you do?
Thanks,
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2020.9
Old 09-30-2020, 10:43 AM
I certainly will. Thanks for the tip.
I read reference to what you propose and I only investigated it a little. I am so used to marking spots with pause that I may need to teach this old dog a new trick.
Again, thank you. I'm sure I will have more Qs.
Old 09-30-2020, 10:47 AM
I update my graphics card, but that wasn't the cure because the issue persisted after that change. I'm not certain WHAT exactly I did--or didn't do. I know I held "N" key while loading once; all that did was bring me to the interface that is under Tools drop-down, right?
I'm sorry if my newbieness is annoying. I work more easily with Vegas Pro--Sony/Sonic Foundry/Magix--whichever; in fact, all of them.
The good thing is, I learn quickly.
Cheers
Old 09-30-2020, 05:47 PM
cwsand's Avatar
No problem - that's why we have the forums! Glad you got your issue resolved.
Help Us Help You
Chris
PreSonus Digimax LT
Pro Tools HD 2020.9
Pro Tools 10.0 crashes while booting up SlothOner macOS 7 06-19-2012 01:18 AM
Error message while booting Pro Tools antonis Pro Tools TDM Systems (Mac) 3 01-26-2010 07:49 AM
Dual booting Pro Tools? Mix Master Factories Pro Tools TDM Systems (Mac) 5 12-05-2008 04:32 PM
Problems booting Pro Tools devapro Pro Tools TDM Systems (Mac) 7 07-14-2008 10:46 PM
pro tools not booting up rand13 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-08-2007 09:51 PM
