Old 04-30-2017, 03:01 PM
jdogric12 jdogric12 is offline
Default Should I go from El Cap to Sierra? [solved]
HI gang. I'm on a late-2011 MBP 13" that I've stuck some more RAM into (now has 16GB 1333 MHz DDR3), El Cap 10.11.6, 2.4GHz Intel Core i5.
And I'm on ProTools 12.5.2.511.
Interface is a Focusrite Saffire Pro 40, which I run a Presonus Digimax D8 into to give me 8 more channels, via optical, if it matters.
Would upgrading the OS X to Sierra help me or hurt me? I feel like my computer might work better with the newer OS, and might be better for Final Cut Pro X. But if it's gonna screw PT I won't do it!
Thanks! J
Old 04-30-2017, 04:55 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Should I go from El Cap to Sierra?
I'm on an early 2011 MBP with 16GB RAM and SSD system drive on 10.12.4 and have had no issues. Most people seem to think Pro Tools runs better on Sierra. I'm not sure what the latest officially supported version is, but it's all good for me.
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS Catalina 10.15.7
Pro Tools HD 2020.9.1
Old 04-30-2017, 11:17 PM
JFreak's Avatar
JFreak JFreak is offline
Yes!
Compatibility chart here.
Janne
Old 04-30-2017, 11:23 PM
clausiii's Avatar
clausiii clausiii is offline
Sierra for sure! MBP 2012 here! No issues!
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.9.1
Avid S1
Avid Dock
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 05-01-2017, 05:29 AM
Thanks everyone!
Old 05-01-2017, 05:53 AM
JFreak's Avatar
No prob :)
Janne
Old 05-02-2017, 06:42 AM
Originally Posted by JFreak View Post
Yes!
Actually, now that I look at that chart, I see Sierra is not added until 12.6. I'm on 12.5.2.511. This won't be a problem? or am I reading the chart wrong?
Old 05-02-2017, 07:21 AM
JFreak's Avatar
Default Re: Should I go from El Cap to Sierra? [solved]
It shouldn't be a problem, but not supported either
Janne
Old 05-02-2017, 09:37 AM
Oroz Oroz is offline
I'm on 12.5 (a little bit behind the original poster) Do you guys recommend me to upgrade to Sierra as well?
Old 05-02-2017, 10:03 AM
JFreak's Avatar
For what I've seen, Sierra is much better than ElCrap in every way. Support documents though should be your first guideline, not recommendations.
Janne
Can't reinstall PRO TOOLS LE 8 with new macOS Sierra 10.12 [solved] Corinna macOS 52 03-24-2017 01:54 PM
"your computer restarted because of a problem" Sierra boot problem [SOLVED] reichman Pro Tools 12 0 02-22-2017 02:43 PM
Sierra Install Gone Bad - need help [solved] Carl Lie Pro Tools 12 2 12-22-2016 07:04 AM
HDX and Sierra Jeffrey Talbot Pro Tools HDX & HD Native Systems (Mac) 5 11-16-2016 03:21 PM
SOLVED>>Need HELP, SUPER ASAP.< audioindo Pro Tools TDM Systems (Mac) 18 04-21-2007 05:43 AM
