Old 01-24-2017, 08:37 AM
chadjhughes chadjhughes is offline
Default Any problems with PT 12.7 HD and Sierra 10.12.3?
I'm about to pull the trigger on upgrading my system today and I saw that Avid's compatibility chart lists PT 12.7 HD as being compatible with Mac OS 10.12.1 but not the latest version 10.12.3.
Wondering if anyone has tested 10.12.3 and PT 12.7 HD versions together without a mushroom cloud appearing over their studio?
I'm asking because Avid did the same thing when they released compatibility for El Cap and said PT 12.5 wouldn't work with 10.11.6 but would with 10.11.1, when in fact it was fine form the release date. They just didn't officially support it until later.
Any feedback or problems to report would be appreciated!
Old 01-24-2017, 09:09 AM
clausiii's Avatar
clausiii clausiii is offline
Default Re: Any problems with PT 12.7 HD and Sierra 10.12.3?
does not work here on my test drive!!!
EDIT: well, now it opens after starting PT with the N key and the tried a different sound device. Then it opened. Then switched back to my desired device. All ok now...
...strange...
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.9.1
Avid S1
Avid Dock
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 01-24-2017, 10:10 AM
Ianduarte Ianduarte is offline
Working Perfectly here. Pro Tools 12.7 on Sierra 10.12.3
Old 01-24-2017, 11:21 AM
john1192 john1192 is offline
i feel bloody from all this Cutting Edge talk ... i hope you guys Backup your systems before doing these .dot updates of Sierra .. just sayin' ... safety first ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Old 01-24-2017, 12:34 PM
clausiii's Avatar
Yes you are right, and i said TEST drive ;-)
My ears! My ears!
clausiii
ProTools 2020.9.1
Avid S1
Avid Dock
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 01-24-2017, 10:43 PM
I always backup before updates. Safety first, but so far so good. I am happy with 10.12.3 and Pro Tools HDN 12.7
Old 02-06-2017, 01:13 PM
mavericksound mavericksound is offline
I am on PT 12.7.0 and Sierra 10.12.2.
My only issue is that I now keep getting this RAM alert:
"Physical RAM is running low. For better performance, reduce the disk Cache Size in the Playback Engine or install more RAM. You have 2G of unused space in the Disk Cache."
I have 16 GIGs installed, and have NEVER had any issue.
It seems like the RAM is staying used up in the Cache or something like that. Never had it before I updated to Sierra.
It's pretty frustrating. Really shouldn't have switched yet!
Old 02-06-2017, 01:46 PM
dankin dankin is online now
I've recently started getting that message on 12.5.1 on Yosemite, so I don't think it has any thing to do with Sierra. That's on my tower with 24gigs of ram and in sessions that do not have any VIs going. I'm thinking there's a ram leak somewhere.
2018.3 HD, MacPro 5.1 12core 3.46, 24gig ram, OS 10.12.6, 2014 MPB 2.8, OS 10.12.6
Old 02-06-2017, 02:11 PM
Interesting. It was only after updating to Sierra for me.
Old 02-06-2017, 02:21 PM
what was your disk cache set at? It's weird for me because it just started happening in the last month, the only thing I've done is up date some plugins that were not on the latest version.
HDX with PT non HD on Sierra ? JJdelRio Pro Tools HDX & HD Native Systems (Mac) 14 04-26-2017 07:47 AM
digi 002 Rack Problems under Sierra Wubslin FireWire and USB Audio Interfaces (Mac) 2 02-21-2017 02:15 PM
Can't get Sierra on 5,1 Mac Pro Carl Lie Pro Tools 12 21 01-06-2017 04:46 PM
HDX and Sierra Jeffrey Talbot Pro Tools HDX & HD Native Systems (Mac) 5 11-16-2016 03:21 PM
OSX Sierra jack s. macOS 25 11-05-2016 04:51 AM
