Old 04-28-2010, 04:35 PM
DJ Hellfire DJ Hellfire is offline
Question Dverb test: Stereo or Mono Dverbs?
I just realized that although the Dverb test instructions mention to use a mono track for the test tone, it doesn't specify mono or stereo for the actual Dverb audio tracks. Or does it not matter? Stereo plugs do use more CPU than mono, correct?
www.HellfireBeats.com
Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61, Focal Alpha 80, UAD 2 Apollo Quad, UAD 2 Satellite Quad, UAD 2 Octo PCIe, Neve R6 "Lunch Box", Neve Portico 511, Neve Portico 551, Neumann TLM49
Pro Tools 2018.10
Mac Pro 4,1 (5,1 upgrade), Early-2009, 3.46GHz Nehalem 12-Core, 32GB RAM - OS 10.12.6
13" MacBook Pro, Late-2011, 2.4GHz Dual Core i5, 16GB RAM - OS 10.12.6
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - OS 10.12.6
Old 04-28-2010, 04:43 PM
Shan's Avatar
Shan Shan is offline
Default Re: Dverb test: Stereo or Mono Dverbs?
Yes, this does matter and stereo instances of plug-ins do indeed use more CPU. When one creates an audio track, the default setting is mono which needs to be used and remained unchanged:
The Dverb 2.0 Test
Please make sure that RTAS Engine Ignore Errors During Playback/Record box is unchecked
Start the computer. Create a brand new 24bit/48k Session on your audio drive for the Dverb test. Open up the system usage window in PT. Then, go to Setup > Playback Engine... > and make sure the RTAS engine: Ignore Errors During Playback/Record(may cause clicks and pops) is NOT checked. Also, Go to your buffer setting and select 1024(CPU usage must be 95% or highest possible). Set up your time line ruler for Min:Secs. You want to be in grid mode and set up your grid for Min:Secs and 1 second. Create one mono audio track. Take the selector tool, put it on the 5 minute mark in your audio track and drag this to the start of your session. You will now have 5 minutes selected in this track. Go to AudioSuite > Other > Signal Generator and click on the "process" but. You should now see a 5 minute test tone. Create another audio track and insert 5 Dverbs in all the inserts. Record arm the Dverb track. Click on the track name so it is high lighted white, and hit shift+alt+D then hit enter. Record arm the new track and continue this pattern. You want to be able to record WITHOUT THE TEST TONE BREAKING UP!! Keep adding Dverbs and recording. If the test tone starts to breakup, then delete some Dverbs until you can hear a SOLID TEST TONE for 5 MINUTES. This is VERY VERY important. The test tone has to be 100% solid!!!
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 04-28-2010, 04:51 PM
Yeah, I saw the "create another track" but was unsure. I think when I built my boys i7 a few weeks ago, I might have used stereo dverbs.
Pro Tools 2018.10
Old 04-28-2010, 05:13 PM
Shan's Avatar
No worries. Just redo the test and then you'll know. It's not a 2 to 1 ratio by the way so it's best if you redo the benchmark at some point.
Shane
As a test i ran 80 mono and 16 stereo on laptop 44.1 16 bit crizdee Pro Tools 9 0 11-15-2010 11:16 AM
Stereo Aux vs Mono Aux and Turning that Mono into stereo via a stereo Plugin JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-14-2010 09:01 AM
40 Dverbs in the dverb test petersrin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-25-2009 11:54 PM
Mono DVerb plugin test on 8-Core Mac Pro bortraws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 54 10-21-2009 12:33 AM
Mac Pro 8-Core = 406 Mono Dverb inserts! My stress test. MindDead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-27-2007 12:50 AM
