Old 04-29-2007, 01:53 PM
bortraws bortraws is offline
Default Mono DVerb plugin test on 8-Core Mac Pro
Well here it is then, per request.
The Mono DVerb plugin test on the 8-Core Mac Pro in Pro Tools LE 7.3.1.
First the specs:
Mac Pro 8-Core 3 GHz
4 GB RAM
Mac OS X 10.4.9
H/W Buffer Size: 1024
RTAS Processors: 8
CPU Usage Limit: 85%
24-bit, 48 KHz session
I created 48 mono audio tracks and inserted DVerbs on all inserts ... but hold on, there's more ...
because i couldn't create more audio tracks i created Aux inputs and after 9 Aux inputs it gave me the well known Buffer Size error.
So in total i had a whopping 248 DVerbs inserted and playing back audio on all tracks and routing signals from sends to the other 9 aux tracks. The last aux track only had 4 plugins inserted.
So there you have it, 248 DVerbs in total !!
Any other requests for tests i can perform?
Bortraws
Old 04-29-2007, 05:13 PM
LoZion's Avatar
LoZion LoZion is offline
Default Re: Mono DVerb plugin test on 8-Core Mac Pro
Can you try various buffer sizes? (And are we talking 44.1k/24?)
thanks,
"The secret in life is to have no fear"
Fela Anikulapo Kuti
Old 04-29-2007, 05:50 PM
Phil Jeffers Phil Jeffers is offline
Great stuff!!!
Can you set the hardware buffer to minimum and drop into record on 24/32/48 channels... then do the same with d-Verbs.
Ta, Phil
Old 04-29-2007, 05:57 PM
P.S. please set CPU usage to 95 or 99% (all 8 cores).
Old 04-29-2007, 06:01 PM
P.P.S. please have the CPU uage window open also... check for spikes and gauge level (one third, half, three quarters etc.)
Thanks man, legend!
Old 04-30-2007, 04:48 AM
Woa, that's a lot of requests. I will change the playback buffer size to 128, 512 plus 1024 again and set the cpu usage to 99% to see what it does then. Although that is really really pushing it. But hey, that's what you want isn't it?
I already have recorded at different tracks with the current session without a problem. Oke, it becomes a little bit slower in response, but still very very usable. The spikes in the current session were almost none. With my DP 1.8 G5 the cpu usage meter was always very nervous. With this machine the little line stays close to the green bar without jumping nervously. I'll see what it does with the other settings.
I'll be back soon with the results.
Bortraws
Old 04-30-2007, 05:32 AM
Okay, here it is. The results of even heavier mono DVerb tests on the 8 Core Mac Pro
All these settings below allowed me to comfortably record multiple tracks and of course play them all back.
Hardware Buffer Size: 1024 samples
CPU Usage Limit: 99%
audio settings: 48KHz, 24-bit
48 audio tracks and 17 aux input tracks with a total of 323 DVerbs
Hardware Buffer Size: 512 samples
48 audio tracks and 1 aux input tracks with a total of 241 DVerbs
Hardware Buffer Size: 128 samples
30 audio tracks with a total of 150 DVerbs
By the way, i have the X1900XT graphics card with 512MB Video RAM. This really made a difference. The Meters all kept visualizing the signals smoothly. So it's recommendable to buy a better graphics card.
Any other requests ?
Bortraws
Old 04-30-2007, 06:35 AM
GORILLA GORILLA is offline
Impressive! What can a $7,995.00 H.D. 1 system do?
GORILLA
METAL LABS
Old 04-30-2007, 06:40 AM
Wow!!! Awesome... thanks again dude.
Cheers, Phil J.
Old 04-30-2007, 07:12 AM
GORILLA
Well, maybe someone else is willing to do that test. I have access to an HD system, but i am not at that location very often.
Now that computers become more and more powerful. I wonder how they measure up against an HD system. Purely processor vs dsp of course. The other positive elements that speak for an HD system are obvious.
Anyone??
Bortraws
Dverb test: Stereo or Mono Dverbs? DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-28-2010 05:13 PM
DVERB test help synchronic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-08-2009 12:26 PM
Mac Pro 8-Core = 406 Mono Dverb inserts! My stress test. MindDead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-27-2007 12:50 AM
Confused: dual core and Dverb test WideO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-25-2006 01:13 AM
Any core duo vs. core 2 plugin performance test? DC2light 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-01-2006 08:37 PM
