Confused: dual core and Dverb test
I'm doing some DVerb tests on my Toshiba Satellite A100 373 (Core Duo 1.66 Ghz) laptop with 7.3 and MBox Pro, and I'm a bit confused.
Whilst setting the DAE to 2 processors (CPU limit 90%), I can record 32 tracks with 70 DVerbs. CPU constantly hovers around 88 - 89 %, even when not recording. Records for 5 minutes, no problem. When I close the session, change to 1 processor (CPU limit 99%) and reload the test, I only see about 15 % CPU usage, but hitting record immediately gives me a buffer error. Restarting Protools, changing CPU affinity (as I had to do with 7.1.2), then load the session does not change anything. OK, it's obvious I'm better off with using the 2 CPU's, and it's not really a problem, but I wonder why there is such a difference in (alledged) CPU usage ? |
Re: Confused: dual core and Dverb test
How does it perform in an actual mix session?
5198 Studios |
I don't have any serious data on real world application yet I'm afraid. It's OK for the small projects/demos/songwriting I've done so far, and it certainly seems possible to get a good sound out of the setup.
I don't think the Toshiba is recommended, it took me quite a bit of tweaking to get it this far, and 70 DVerbs isn't really a lot compared to what others are getting. OTOH, there seem to be no serious incompatibility issues with Protools. |
Should I still do a DVERB test? | PeterGreen | Pro Tools 10 | 9 | 01-05-2013 07:20 AM |
Mono DVerb plugin test on 8-Core Mac Pro | bortraws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 54 | 10-21-2009 12:33 AM |
DVERB test help | synchronic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-08-2009 12:26 PM |
Mac Pro 8-Core = 406 Mono Dverb inserts! My stress test. | MindDead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-27-2007 12:50 AM |
G5 Dual 1.8 vs G5 Dual 2- DVERB Speed Test | Sound Man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-29-2003 03:18 AM |
