Old 12-06-2019, 03:16 AM
gafyn gafyn is offline
Default Genelec 5.1?
What are your thoughts on Genelec 8320 / 8330 with 7350 sub for a 5.1 setup for television broadcast?
Room size = 18ft x 12ft approx
Using Protools 2018 with D-command.
I'm also running short on XLR I/Os on my patch, so I can use the digital XLR options and ethernet.
Thanks everyone.
There is no Spoon
Old 12-06-2019, 09:25 AM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: Genelec 5.1?
You'd love it. Plenty of power for that size room. I have a similar size room but I use the JBL LSR4300 series so I'm partial to that. Might be worth looking into if you can find a set. I use it with AES.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 12-06-2019, 02:23 PM
dr sound's Avatar
dr sound dr sound is offline
Check out the 8330 specs for max spl:
https://www.genelec.com/8330a
You need up to 20 db so if your monitoring at
82 for example you will need 102 .
It does 104.
If you monitor any higher you MIGHT run out of headroom
depending what you are mixing. If you do decide on
going with the Genelecs it only makes sense to go with
the 8330.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 12-07-2019, 12:06 AM
tklaavo tklaavo is offline
To be able to use Genelec's built-in bass management you need to use analog inputs into the sub and continue analog from there to the 5 monitors. If you want to use AES/EBU, you'd need the Genelec 9301a interface
The older 7200 series subs had multi-channel AES inputs, which work very well, so if you can find one of those, it would suit you well.
Tuomas Klaavo
Helea Sound Post Production Oy
Old 12-07-2019, 02:48 PM
paulo m's Avatar
paulo m paulo m is offline
8330 (or 8331 if you have the budget) and 7360 sub would be my recommendation for your room dimensions. If you want to go AES and bass management on top of the Lfe channel, you´ll need the 9301 unit.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 01-30-2020, 01:45 AM
Hey thanks guys - I've only just seen these posts (I don't get email notifications like I used to, must look in to that.)
Been super busy so 5.1 has been on hold.
Just saying thanks for now.
There is no Spoon
Old 05-03-2020, 10:13 AM
ronnievanoverveld ronnievanoverveld is offline
I have a Genelec 8020/7050 5.1 surround setup. Maybe I want to upgrade to bigger satellites, as I want a more full range speaker instead of base management. I sometimes find it difficult to make mix decisions.
Would a 8330 setup be a good step up? Or is it too close to the 8020’s? Also I’d love to use SAM.
Ronnie van Overveld - Sounddesigner - The Netherlands
Mac Pro Trashcan OSX Mojave, ProTools 2021.3.1 Ultimate, Focusrite Red4pre, Avid S3, Avid PT DOCK, AJA IO XT
Old 05-03-2020, 04:01 PM
paulo m's Avatar
Hi think that the 8330 will be a very good step further, comparing to the 8020.
Having said that, I don´t see the problem of bass managing it, in particular if you use GLM.
Regards,
Paulo M
Old 05-04-2020, 12:18 AM
Thanks Paul.
Regarding the specs, the 8330 go a lot further in bass, so that would be great.
Since I moved to another studio, I'm having doubts with my mix decisions. I have measured (only stereo) a couple of times with Sonarworks, the figures seem to look good, but not feeling really confident when mixing.
Somebody else having those problems?
Old 05-12-2020, 03:22 AM
LDS LDS is offline
Originally Posted by ronnievanoverveld View Post
Thanks Paul.
What has changed between the two setups?
I had a lot of trouble feeling comfortable with 8320s. The biggest help was adding a bit more space between the listening position and monitors, but the was the result of throwing up the centre monitor and running GLM from various distances from the front wall. It didn’t reduce specific nodes in the room, but it did alter the overall low to high frequency balance.
Genelec also have some pretty good setup/monitor placement suggestions too. If you haven’t had a look, I would definitely check them out. Once you find a spot that measures nice and flat, run GLM, then listen to some material that you are familiar with. You can tweak GLM to make it sound a little closer to what you expect. I found the default GLM measurement to be a tad light in presence for how I usually like to mix.
HTML code is On
Which Genelec's for ls/rs/lfe? Dolly Post - Surround - Video 2 03-05-2009 09:07 AM
I want to buy GENELEC .... help cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-17-2006 03:10 AM
Genelec or M&K? Strider General Discussion 10 02-07-2002 09:24 AM
Genelec or else.... lucian Tips & Tricks 21 02-05-2001 12:40 AM
Genelec 1032A pyro Tips & Tricks 5 10-24-1999 08:58 AM
