7.4 No import video to playlist. The Problem is resolved!!!
I update my Pro Tools from 7.3 to 7.4
Now my Pro Tools no import video. My Quicktime version is 7.1.5 In the display : "Can't import the selected video files because it does not contain any video frames" |
Re: 7.4 Pro Tools No import video to playlist
Try doing a 'clean uninstall' of every version of Pro Tools that has been on the machine.
IE run the clean uninstall from EACH of the Pro Tools installer disks that've you've ever used on the machine. I think this error comes from a mixture of PT versions. |
What OS version and System specs are you running?
I delete All versions of Pro Tools before the instal Pro Tools 7.4
My system is 10.3.9 |
7.4 isn't supported on any version of 10.3, you can only use up to PTLE version 6.9 on the OS you are currently running. You need Tiger (OS 10.4) for compatibility with your 7.4 upgrade.
Compatibility Grid |
Sorry, my System version is 10.4.9.
I update 10.4.8 to 10.4.9 when I instal Pro Tools 7.4. Now I work whith my Backup system in external Firewire disk, whith my Pro Tools 7.3 and my System 10.4.8 and all work Ok. Some problem of communication 1394... |
So you still never got the 10.4.9 / 7.4 drive working right? You're saying you're using a different drive and PT 7.3 externally and that is working?
There are others having this issue, so if you do find a solution please post it. |
This sounds like the format of the video causing the problem.
What is the type of video file is it? Re-export, or transcode the video to 320x240 DV Stream, and then import that into Pro Tools. This should work. |
I work whit .mov video files always.
Now Pro Tools only work with DV format. ??? What is the problem??. The video files .mov working in 7.3 and no in the 7.4 versión? |
Yes , but this external drive is a backup of my system and my old configuration.
With the system 7.4.8 an Pro Tools 7.3 |
Resolved: BTD problem | Khatru | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-16-2010 07:19 PM |
Import Video in PTLE 8 problem | edb200 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-02-2009 09:17 PM |
video import - audio problem | roykamen | Pro Tools TDM Systems (Mac) | 0 | 10-06-2008 11:41 AM |
Import Audio From Video Problem | mars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-04-2007 09:50 AM |
