#41
Re: Sample Rounding Issue!!!!
Yup - those screenshots are useless. Looks like I got mayo smeared on my glasses
#42
I will try again when I return to my studio on Monday to show you guys clearer images. The timebase is set to ticks but the issue happenes if set to samples as well.
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions |
#43
#44
Ok thanks, I will try that if I cannot get the images clearer
#45
i use studio one and pt hdx daily. the gui in pt is better and is more snappy. I still prefer mixing in pt and have a lot of $$$ invested in their hardware and software. there is no better game in town for low latency and analog hardware integration.
But studio one 4.5 has me thinking...many of the new updates are features that kept me out of using studio one as my main daw. Transferring files from s1 to pt is a piece of cake. S1 will render the entire session completely with time stamped audio files with just a few clicks of the mouse. That is what drew me to studio one and had me leave logic. it significantly cut down my time in transferring files by at least 90%. ej |
#46
If you are in "ticks" mode, and your clips are created to be for example exactly 1/4 note then they will act correctly and you shouldn't have a problem. Pro Tools allows users the flexibility to have multiple timebases working in a single session and to move tracks freely between sample and tick timebase - I suspect that the people having problems with this have either created or edited clips on a track in "samples" mode and then changed it to "ticks" mode and expect everything to work just fine - it usually will not. I'd be very curious to see an example of sample rounding error on a tick based track with material that's been created or conformed to the tick grid - not saying it's not possible that there's a bug, but I'd want to see it.
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 05-26-2019 at 06:13 PM. |
#47
"But studio one 4.5 has me thinking...many of the new updates are features that kept me out of using studio one as my main daw. Transferring files from s1 to pt is a piece of cake. S1 will render the entire session completely with time stamped audio files with just a few clicks of the mouse. That is what drew me to studio one and had me leave logic. it significantly cut down my time in transferring files by at least 90%"
Um, Logic does the "exact" same thing (unless I'm missing your point) I use it with every piece of music I make... I do all the MIDI/instrument recording in logic and then export everything as audio files and do all the mixing in PT, works a treat! As for the sample rounding issue, well, it's been with us since version 11 (64 bit re-code) and is a PITA but one that I've just had to become used to and find suitable work arounds, it may just my imagination but it appears to be more "pronounced" in 2019.5 |
#48
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard https://soundcloud.com/2b3productions Last edited by foxes; 05-27-2019 at 03:37 AM. |
#49
Here's a video : https://youtu.be/jvlz8eDFZIs 1. New session 2. New MIDI track 3. Create 4 bar clip 4. Now zoom right in and pull the clip in (or out) ever so slightly. The edit section length will still register as *exactly* 4 bars 5. Now go to duplicate the 4 bars and watch the clips eventually drift off the grid. Obviously to a certain extent this is expected behaviour; the problem is that "edit section length" isn't accurate enough to be able to see if you have *exactly* 4 bars or some tiny fragment more or less. This "rounding error" may be exacerbated with certain combinations of tempos and sample rate of course. |
#50
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
Sample Rounding | budda963 | Pro Tools 11 | 1 | 07-08-2013 06:07 AM |
sample rounding error in pro tools 10??? | DarkDayz | Pro Tools 10 | 6 | 11-02-2011 03:22 AM |
PT and Sample Rounding WILL cause Issues when Copying | 25ghosts | Pro Tools TDM Systems (Mac) | 7 | 07-01-2011 02:25 AM |
Sample rounding issues | bigdoghat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-13-2007 08:20 AM |
Sample rounding, ticks, etc | voce | Pro Tools TDM Systems (Mac) | 1 | 08-03-2005 05:26 AM |
