Old 04-13-2021, 09:00 AM
flautista's Avatar
flautista flautista is offline
Default Protools 8 last MAC system should works
Please help
Protools 8 last MAC system should Works
Jascha Koneffke flutist
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
RAM 24Gb corsair 1600 (3 sticks)
9-9-9-24
MAC
MacBookPro i7 2,3 15"
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 04-13-2021, 09:43 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Protools 8 last MAC system should works
Excuse me but what was the question?
In case you want to know about PT and OS compatibility, bookmark this page.
And when you need to know which OS any Mac can run, www.everymac.com is your friend. Remember if some Mac model has been first released with certain OS version, YOU CANNOT install earlier version because the drivers are not available for separate install. That OS is the earliest possible, no way getting around that.
Janne
Old 04-13-2021, 09:54 AM
flautista's Avatar
Originally Posted by flautista View Post
Please help
Sorry the question is
Wich is the last MAC System that you can use Protools 8
Of Course using an Avid interface
www.prodmusica.cl
GA-X58A-UD3R[/
I7 950
9-9-9-24
MAC
RAM 16gb
PT 11.3
003 Rack
MBox 3 Pro
Old 04-13-2021, 10:18 AM
JFreak's Avatar
As said, PT8 support ends with Snow Leopard. Anything that can run that can also run PT8 (but you just cannot install Snow Leopard to a new Mac, needs to be old hardware and that info you can get from www.everymac.com. Pick the model you are thinking, one of the first information there is the model name used by Apple, for example MacBookPro11,3 and then scroll down the specs and you see "Pre-Installed MacOS: 10.9" which means you cannot install Snow Leopard to that hardware)
Janne
[IMG] code is Off
Latest OS X that works with The system 5MC The golfer System 5 6 01-05-2020 01:01 PM
Mbox 2, Input works, sound for non-protools works... rmiller9969 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-13-2011 04:13 PM
8.0.1 Finally my system works!! LUISMI 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-10-2009 01:40 PM
It Works! My Protools system works!!! Woooooo Hooooo!! Siberian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-19-2003 08:48 AM
old system still works jerry mack Digidesign Hardware & Software 4 04-19-2002 07:37 PM
