  #21
Old 08-19-2019, 09:28 PM
Neale Neale is offline
Default Re: Plugin GUIs disappear at first
To be clear - I only see "Select by Touch" in the EuControl Settings/General page. When selected, the issue presents itself whether I select by faders or the touchscreen. When this option is NOT selected, of course the faders do not do the job of selecting, but the issue still presents itself when selecting a different channel via the touchscreen.
So... no difference, problem persists with or without that option.
  #22
Old 08-19-2019, 09:40 PM
EddieJones's Avatar
Can you try one more thing...press the Sel button next tot he Fader and see how they behave ? Thanks
  #23
Old 08-19-2019, 10:15 PM
Same behaviour when I do that.
  #24
Old 08-20-2019, 11:48 AM
EddieJones's Avatar
I see the issue...will fix...
  #25
Old 08-20-2019, 12:06 PM
Sounds good.
Thanks!
  #26
Old 09-06-2019, 06:50 AM
PhilSchroeder's Avatar
PhilSchroeder PhilSchroeder is offline
Will fix? What does that mean? I'm having the same problem and it's driving me crazy. Is there a bug in Eucon, a setting that needs to be changed? Having plugins disappear the second I instantiate is just freakin' ridiculous.
MacPro 2013, 12 core, 48G RAM
OS 10.14.4
Apollo x6 & Twin
Pro Tools 2019.5 (buggy!)
Avid Artist Mix
Studio One 4.5
  #27
Old 09-10-2019, 12:51 PM
EddieJones's Avatar
Will fix means We will fix it. Hopefully in 19.9 this month(if its not a massive amount of work, otherwise it will have to go into the release after)
  #28
Old 09-13-2019, 08:23 AM
Hi Eddie,
is there any way to stop the Artist Mix from constantly activating the FLIP CHAN button? Also: Is there a way to temporarily stop PT from auto-opening the EQ PAN or send window? On the Mix you can not fully de-select all of the modes so something is always popping up wether you want it or not. Changing the settings in EuControl all the time is not really a good way.
Is there a way to tell Eucon to drop out of this auto-open mode and then when you need it to do it?
Thanks!
Frank
PTHDn 2019.6 (OSX10.14.4), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM
Plugin settings disappear when reopening the session - PT 10.2 Luke83 macOS 0 07-27-2012 08:06 AM
Ugly parameter-markers in plugin guis after upgrading to Win7/PT 8.0.3 RiF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 12-20-2010 08:31 AM
Plugin inserts disappear? D3lta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-07-2010 10:49 PM
mbox1+GUIs= dropouts mrtunes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-04-2006 12:55 PM
Plugin GUIs cause crash? Snitz Pro Tools TDM Systems (Mac) 6 08-31-2005 08:12 AM
