Old 08-14-2010, 11:43 AM
EarBud EarBud is offline
Default 8.0.3 Last Version Compatible with XP/SP2?
Hello,
After several weeks, I FINALLY have a working system running PT 8.0.
I'm using XP Pro with SP2, and DO NOT want to get into updating to SP3. However, I would like to run the latest version of PT that's compatible with SP2.
I know that 8.0.4 requires SP3, so that's out.
So could someone please confirm that 8.0.3 will work with SP2 before I install it and risk any complications?
Thanks!
Old 08-14-2010, 12:05 PM
spkguitar's Avatar
Default Re: 8.0.3 Last Version Compatible with XP/SP2?
Really, honestly, you should be using SP3. I know that 6.9 and higher require SP2, and PT 8.0 and above are officially supported on SP3, but not tested with SP1 or SP2.
I very sincerely thought SP3 was a requirement already at 8.0
You also might want to consider making an upgrade plan: 8.0.4 is the last version of Pro Tools that will support XP in any form.
Old 08-14-2010, 12:38 PM
spkguitar,
Thanks for the input. I'd update to SP3 if I had a factory XP/SP3 installation disk (maybe) - no more online Microsoft updates for me, though!
If you only knew what I've been through the last few weeks...
Just getting to this point has been an absolute nightmare. Now that I've got 8.0 working, I don't want to take any chances. I'm not even putting it online (any PT updates will be transferred from my "Internet" computer to my "PT" computer via thumbdrive).
If I can't get confirmation that 8.0.3 works with SP2, I'll probably just use 8.0 as is - at least until I upgrade machines.
I think I'm what they call "snakebit" :>)
Old 08-14-2010, 01:02 PM
Benoni's Avatar
Benoni Benoni is offline
I agree here, SP3 had many improvements for XP.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-14-2010, 01:04 PM
Benoni's Avatar
Originally Posted by EarBud View Post
spkguitar,
Get Acronis Home 2010, make a clone of the drive to another hard drive. Then make an image(you can store the image on the cloned drive) then update to SP3. If anything goes wrong either pop in the clone drive and get to work, or restore the image and get to work.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 08-14-2010, 01:38 PM
Yikes!
It looks like there's no consensus at all for me staying at SP2!
Assuming then that I do update to SP3,
1) Can I go directly from 8.0 to 8.0.4 with the 8.0.4 update (no intermediate steps)?
2) Would I WANT to go to 8.0.4? From what I've read on the DUC, I sort of get the impression that 8.0.3 is a bit less buggy (and I probably won't be upgrading to Windows 7 until I build a bigger machine).
Thanks.
Old 08-14-2010, 01:54 PM
Running Pro Tools 8.0.x with Win XP SP2 is an unsupported Pro Tools system. Pro Tools 8.0.4 is EOSS for Win XP.
Aaron Mulqueen - 001 HD Native
Old 08-14-2010, 02:03 PM
Benoni's Avatar
Yikes!
Thanks.
#1: Yes. You need 8.0, 8.0.1 or 8.0.3 installed before you can update to 8.0.4
#2: Thats up to you. As noted, 8.0.4 is the LAST PT to support XP and Vista.
If 8.0.3 works, then stick with it, update to cs2 and stay there until you upgrade to Win 7. I cant speak for the stability of 8.0.4 on XP as I haven't used XP for a few years.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 08-14-2010, 02:30 PM
Okay All,
Very good information! It looks like I've still got some work to do...
Thanks.
Old 08-14-2010, 04:58 PM
The Weed's Avatar
The Weed The Weed is offline
Sounds like a new song with chorus/chant...Acronis...Acronis...Acronis...Acronis...
Another Grammy!
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
mbox 1 compatible up to which version of PT LE Ludicrous Speed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-23-2008 04:35 PM
ETA of 10.5 Compatible version of PT HD? lampmusic Pro Tools TDM Systems (Mac) 2 01-23-2008 03:32 PM
EQ3 not compatible with version 7.4??? forensicdoc Pro Tools TDM Systems (Mac) 0 11-25-2007 10:09 AM
What is the last version of PTLE compatible w/ 001 shaneotis720 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-2004 10:21 AM
HELP! Early version of D-Fx . . . PC compatible???? takeastand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-19-2002 07:50 AM
