Old 04-05-2017, 04:49 PM
Waverly Harris Waverly Harris is offline
Default how to get xpand2 plugin-ins settings select to work
i cant get the +/- or the plugin-ins setting to work... what did i do wrong? at one point it did work for me ....Help!!!!!!! i messed up my settings
File Type: jpg Screen Shot 2017-04-05 at 7.43.24 PM.jpg (87.6 KB, 0 views)
Old 04-05-2017, 05:14 PM
Southsidemusic's Avatar
Default Re: how to get xpand2 plugin-ins settings select to work
Go to presets above +/- and choose import settings.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-05-2017, 05:29 PM
i dont see what i should pick... which setting do i hit?
File Type: jpg Screen Shot 2017-04-05 at 8.27.20 PM.jpg (85.5 KB, 0 views)
Old 04-05-2017, 08:45 PM
Import settings
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-05-2017, 10:03 PM
unkJE's Avatar
unkJE unkJE is offline
http://www.soundonsound.com/techniques/settings-down
If you want to track down plug-in settings after the fact, it is possible to use the Mac Finder or Windows Explorer to move and copy the plug-in settings files. The Session Plug-ins Setting folder is easy to track down, as it will be in a folder called Plug-in Settings inside your session folder, along with Audio Files, Session File Backups, and so on. The Root Plug-ins Settings folder is harder to find. On a Mac in Pro Tools 10 and below, it is Macintosh HD/Library/Application Support/Digidesign/Plug-in Settings. Within this folder, each plug-in has its own subfolder. On Windows machines, the location is C:/Program Files/Common Files/Digidesign/DAE/Plug-in Settings, and again, each plug-in has its own folder.
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 04-06-2017, 12:01 AM
Yes this is way better hehe
I was in the car and couldn't write this complete
Thanks for stepping in.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 04-06-2017, 09:55 AM
Thanks so much!!!!!!!! Got it
Old 10-25-2018, 10:22 PM
Melody Man Melody Man is offline
I tried this but my plug-in settings folder is empty. What now?
Plugin window follow select? jasenj1 ICON & C|24 2 10-08-2014 07:39 AM
XPand2 does not work under multiple log-ins DaveBMusik Virtual Instruments 5 02-24-2014 02:58 PM
Xpand2 modulation doesn`t work, please help. gaijin001 macOS 3 10-18-2012 07:39 AM
How do you select a preset for a plugin? Mike Landolt ProControl, Control|24, Command|8 4 01-09-2008 07:46 PM
Select Plugin on the 002 and C8 LuisB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-20-2005 11:22 AM
