Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools SE and Essential (Win)
Old 10-19-2013, 09:48 PM
pmc2013 pmc2013 is offline
Default Help! Pop filter not used
Music is part of life. I recorded some tracks without a pop filter. All words that start with PRO, Po come out real strong. Can someone assist me with a pop sound or pop remover software/pop editor or whatever it is called.
Thanks in advance.
Computer: Windows 7, 64 bit.
Interface: M-Audio Fast Track C400
I have Protools SE 8.0.3
Thank you all
PMC Mark Pedzi
Old 10-21-2013, 07:07 PM
soybalm soybalm is offline
Default Re: Help! Pop filter not used
The first thing I would do is to use audiosuite, under eq, and grab the 1 band in high pass mode. Select the P word. Set it for 100 hz or higher depending on how high in pitch the track is.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 10-21-2013, 10:17 PM
I have Protools SE 8.0.3 and I do not see an option or tab that says audiosuite.
Any ideas for Protools SE 8.0.3?
Thank you all
PMC Mark Pedzi
Old 10-21-2013, 10:49 PM
YYR123's Avatar
YYR123 YYR123 is offline
Not in the top menu where u change the playback engine? That menu
Daniel
Old 10-22-2013, 10:37 PM
No I use Protools SE 8.0.3 and it does not have the audiosuite in the top menu.
Any other assistance is appreciated for a pop remover software or editor??
Thank you all
PMC Mark Pedzi
Old 10-23-2013, 04:47 AM
chrisdee's Avatar
chrisdee chrisdee is offline
1) You can use a Notch Filter in the RTAS EQ plugin and automate the plosive.
2) You can draw out the plosive with the pencil tool.
3) Cut and paste a p from another part or re-record, and swap the original with that.
You probably need to use a little crossfade for number 3.
Old 10-23-2013, 07:15 AM
You have it but it might be grayed out if your plugins aren't loading right. I have/had 6,7.4, 9, 10, and 8 on the mac.
The menu bar should be in this order from left to right:
File Edit View Track Region Event AudioSuite Options Setup Window Help
The only difference now is Marketplace was added right before where Help is located and now regions are now called clips.
Old 10-23-2013, 09:20 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Exactly!
The waves linear low-band sounds so good for this that I stopped using pop filters because they screw up the midrange.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Asking About Filter Kade B Tips & Tricks 2 02-21-2012 01:06 AM
pop filter hef Post - Surround - Video 1 07-02-2008 12:35 PM
Any good Filter / Step Filter Plug-ins? Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-07-2006 05:01 PM
pop “filter” Fritz Tips & Tricks 3 12-03-2003 08:28 PM
what pop filter should i get? Felix General Discussion 8 05-19-2003 01:37 PM
