Old 01-19-2021, 12:38 AM
serdeman serdeman is offline
Default My two USB controllers are not playing nice with each other.
Greetings,
I'm new to this forum and hope I have placed this in the correct area.
I am running PT 2020.11 on Windows 10 (v2004. And run as Admin).
And, my issue is with my two USB controllers.
I have a Presonus Faderport v2. It works great when used by itself.
I also brought out my old M-Audio Radium 49 keyboard controller. And, even though the latest driver is for win7, it also works great by itself.
But, when I try to use them at the same time, PT gets pop up windows stating it cannot communicate with each device. Yet, the keyboard controller would still operate instrument plugins, but my Faderport stops working properly. Its fader encoder somehow gets assigned to the Master fader in the session, being properly controlled by the Faderport...but that's it. And, when I'm not touching anything, I get a stuck note that I did not create (sounds like the lowest note available).
*My Windows Device manager show no conflicts or errors.
*PT recognizes each device in the MIDI controller settings page.
*FaderPort is self powered by AC and is on its own physical USB port.
*Radium 49 is USB powered via an Insignia USB3.0 hub (Trackball mouse is only other device in the hub).
Is it possible my keyboard controller is too old, and I need a new one with Win10 driver support? Or, am I missing something in my PT setup?
Would someone be able to steer me in the right direction on where to start troubleshooting this?
Thank you so much,
Steve
Steve Erdeman
Recording | Editor | Mixer
Lenovo legion 5 15IMH05H (Intel i7 [6 core - 12 Thread] @ 4.80GHz, 16GB Ram, SSD 500GB, HDD 1TB, Nvidia Geforce GTX [6GB GPU])
Win 10 Home v2004
Pro Tools 2020.11
Focusrite Scarlett 2i2 IO
Old 01-19-2021, 01:28 AM
Top Jimmy's Avatar
Default Re: My two USB controllers are not playing nice with each other.
I have a faderport and have no problems with my axiom. Im guessing you’re setting up both the faderport and the radium as hui controllers. Don’t. Only use the faderport as a hui controller leaving the radium to be used strictly for playing your midi VIs.
James Cadwallader
Old 01-20-2021, 02:25 AM
Top Jimmy, thank you for your reply. Yes, I did not assign both controllers as HUI.
First attempt = Setting up both under Setup/Peripherals/MIDI Controllers page. Faderport is #1 - Type set to HUI, Recv/Send set to PreSnsFP2. Radium 49 is #2 - Type set to M-Audio Keyboard, Recv/Send set to LegacyKbrd. Doing it this way does not work.
Second attempt = Setting up only Faderport under Setup/Peripherals/MIDI Controllers page. Faderport is #1 - Type set to HUI, Recv/Send set to PreSnsFP2. Radium 49 is now set up under Setup/MIDI/MIDI Studio Setup. Manufacturer set to Generic MIDI. Model set to Generic MIDI. In/Out ports set to LegacyKbrd. Send/Recv channels set to ch16 (Radium 49 set to ch16 as well). Doing it this way does not work either, but the Play/Stop buttons work on the Faderport. And its Prev/Next buttons could only change between my Click track and channel 2 on the mixer - weird.
Well, that's what I got so far.
Thank you for your help,
Steve
Steve Erdeman
Win 10 Home v2004
Pro Tools 2020.11
Old 04-08-2021, 04:57 PM
Hmmm, here's what I'd look at:
"Second attempt = Setting up only Faderport under Setup/Peripherals/MIDI Controllers page. Faderport is #1 - Type set to HUI, Recv/Send set to PreSnsFP2.....Play/Stop buttons work on the Faderport. And its Prev/Next buttons could only change between my Click track and channel 2 on the mixer - weird"
This should be correct, but you left out the 3rd item after the send and rcv ports. That box should be set to 8(thinking maybe you have it set for 2)
"Radium 49 is now set up under Setup/MIDI/MIDI Studio Setup. Manufacturer set to Generic MIDI. Model set to Generic MIDI. In/Out ports set to LegacyKbrd. Send/Recv channels set to ch16 (Radium 49 set to ch16 as well)."
This is the correct place for proper setup, but I'm not sure you have the correct settings. In and Out ports(assuming the Radium is connected via USB) should probably look something like "Radium 49 USB[Emulated]". Send/Recv channels should be all ON(all channels in blue) for send. Recv probably doesn't matter as you won't be sending midi data back to the Radium. Lastly, I would set the Radium to OMNI or ALL midi channels if you can. If you can't, then I would set to use midi channel 1.
Last thing to check: Under the VIEW menu, hit MIX windows shows>Instrument(so Instrument has a check mark). This will add a row across the top of the MIX window showing you(on Instrument tracks) what source Pro Tools is looking at for midi data(signal from the Radium), as well as what VI plugin it should be feeding(for a new Instrument track with a freshly-added plugin, it will usually make the proper connection by default. But if you maybe changed your mind and deleted 1 plugin and then added a new one, the assignment may need to be manually set). Also, put the Instrument track into Record-ready or it may not make any sound when playing the keyboard
Pro Tools 11.3.1 not playing nice with RME Totalmix Swurveman Pro Tools 11 1 04-05-2015 10:50 AM
PT 10 and Digi 003 not playing nice! Piers Gibbon macOS 16 01-21-2013 02:49 PM
Mbox3 on Win7 not playing nice with LE8.0.5 dsoundguy Tips & Tricks 1 12-14-2011 12:57 PM
Does anybody have PTLE7.0 playing nice with Sonar5 daveparker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-01-2006 11:29 AM
My iPod and PTLE 6.2.2 isn't playing nice jpoprock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-04-2004 10:58 AM
