faders automated in mix question
Hi everyone-
I'm kinda stuck on this. I looked at the manual but couldn't figure this out. I want to make one mix group fade down while I make another track fade up- like an inverse pan effect but with faders. I have 4 mono tracks- 3 will fade down while the 4th needs to fade up. Is there some way to set the fader automation so that it reacts in a reverse manner to another group? I would do it manually, but the tune requires fadeins/outs about 50 times very rapidly. Thanks for any help Kevin |
Re: faders automated in mix question
Should be able to just select the regions that you want to fade down say... Track 1,2,3. Select that group for the duration needed. Then CNTL-F or ALT-F cannot remember. The fade window will popup. Use a normal volume fade, not a cross fade and fade it out. There is another quick shortcut key too that will do it when the A-Z keybaord tab is selected. I forget without having my keyboard in front of me. Nonetheless, do a fade on the three tracks, then Select the single track and do the same thng, this time fading it in versus out.
Should be pretty straight forward to do. Good luck! - Doc
MONUMENT SOUND MONUMENT SOUND ON YOUTUBE Monument Sound Facebook "Changing how people hear music one track at a time" |
thanks- but I know how to fade down a group and then fade up the track, what I'm asking is- is it possible to do both at the same time - like inverse panning so that it is mirrored? I have a ton of these to do and I would rather not do them all by hand if possible.
K |
I do not think so... but if so, then it would be new to me. Would be a nice feature too!
We shall see, but I do not think it is possible? WHERE'S RAIL! - Doc
No, there are no preset automation fades.
Rail
Platinum Samples www.platinumsamples.com Engineered Drums for BFD |
Question about digi 003 faders!!! | thebreaksnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-03-2010 09:36 AM |
Question on editing automated events... | Morten R. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-30-2007 01:02 AM |
Question on Faders... | GapeOne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-16-2004 02:16 PM |
MIDI control from 100mm automated faders ? | georgia | General Discussion | 1 | 02-19-2003 11:45 AM |
automated volume question | ssd | Tips & Tricks | 8 | 09-08-2002 08:46 PM |
