Old 03-28-2004, 09:11 AM
mommama mommama is offline
Default midi not working with 6.1.1/XP
Hi-
My Midi in/out for 3rd party applications is not working. I'm running 6.1.1 with ASIO 6.1.1 I've tried everything (install/uninstall- MME refresh etc) and it just doesn't work- even though the 001 is recognized as the MIDI device. Does anyone know what the problem is? I'm at my wits end.........
Thanks
K
Old 03-28-2004, 05:08 PM
Dogcode Dogcode is offline
Default Re: midi not working with 6.1.1/XP
You should fire up your hardware a couple of minutes in advance of booting up your computer.......not after bootup.............dog
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 03-28-2004, 09:18 PM
tele_player tele_player is offline
If that's true, it's a bug somewhere.
Quad 2.5 G5, 4.5G RAM
Old 03-29-2004, 06:46 AM
mfym mfym is offline
I think it's system specific. Midi won't work properly on my system unless I power up the keyboard first. Conversely, if I turn the keyboard off with the computer on, it causes some weirdness with my system - meaning I have to turn the keyboard off after powering down the computer.
mommama: Is your system working better now? If not, can you provide more details of the problem(s) and whatever you've done to fix it.
BTW: I've always heard that you should power up everything else before booting up the computer.
Old 03-29-2004, 10:17 AM
Hi All-
Thanks for the help. I'm not using the Digi 001 for Midi in PTLE, although I recently did try to import MIDI into PLTE and got all "Grey" midi blocks - and they didn't play. Also, no MIDI files play on my computer. There is something fundamentally wrong with my MIDI set up but I don't know what.
Mainy I need the Midi i/o on the 001 for sending Sysex messages. I make sound patches for roland guitar synth stuff as well as the Vox tonelab. I need to send.receive them.
I have two programs which are supposed to work with the machines. The Vox program says "check the Midi setup or conncetion of your device" on startup. The roland program just doesn't work for dump recieve/transmit. Both devices however, SEE the Digi 001 as my MIDI in/out. Cables are OK. It's not fixed by putting the machines on before the computer. Any other ideas? MIDI is definately set up wrong but how can I check this?
Thanks to all
K
Old 03-29-2004, 10:55 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
PT Midi interfaces will not work with the Tonelab editor nor Line6 editor. You will need a chaeap Midiman Uno or something for that. I don't know why.
The grey blocks are because you have set midi view to see regions instead of notes.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 03-29-2004, 11:11 AM
The 001 sent sysex messages before in my earlier PT version with WIN ME. No Midi files play on my computer - even through the media player. How can I check if Midi is set up properly? I'm sure it isn't................
Thanks
K
Old 03-29-2004, 11:37 AM
Cliffy_Boy's Avatar
plug a keyboard controller into the midi in, create a midi track, rec enable and see if the midi travk meter activity.
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
Old 03-29-2004, 01:29 PM
john joe daly john joe daly is offline
I also Am having the problem that i can not get my midi functional with PT 6.1.1 Win XP.
I can create a midi track, set the input as the digi 001 port, but i get no midi activity on the channel!
Is there something that any one else knows about this problem?
I am going mad
I can no longer sync up my second machine with Nuendo 2 using MTC.
There has to be a solution to this!
It all worked fine with PT 5.3.1
Help! Help Help! Help!
I feel the pain of anyone who is havin this problem.
The world is being engulfed in a sea of FEAR!
Old 03-29-2004, 04:51 PM
Same exact problems as me- can anyone help us??
K
PT 11 - MIDI not working dmichael Pro Tools 11 0 10-24-2013 05:37 PM
Midi and ADC not working right in 10 crizdee macOS 15 02-16-2012 01:56 AM
Why has midi input stopped working except with Midi Thru enabled? Martin Dubka 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-11-2008 07:43 AM
002 w/ 6.7 MIDI not working? drewzee87t 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-15-2005 01:53 PM
Midi keyboard not working/flickering midi led 002? bill_e_1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-19-2005 05:44 AM
