Old 07-16-2023, 02:03 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default Save Copy In Vs Export
Hey everyone,
Apart from the available options, is there any significant difference between copying a session (Save Copy In) and exporting all tracks in the session as a new session? Or importing all tracks into a newly created session?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 07-16-2023, 03:21 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Save Copy In Vs Export
Exporting a track obviously only delivers audio, not any session data such as plugins used.
Janne
Old 07-16-2023, 06:23 AM
its2loud its2loud is offline
Not true at all. Look up Export Selected Tracks as New Session.
To the OP.. there is virtually no difference when using for an entire session. . It’s just a matter of what you need for each operation when you don’t need the entire session.
Old 07-16-2023, 08:14 AM
smurfyou smurfyou is online now
Well exporting selected tracks wouldn’t include unused media in the bin. So that's the main difference.
~Will
Old 07-16-2023, 08:40 AM
Rich Breen Rich Breen is online now
They are essentially the same and bring up the exact same export dialog; "Export Selected..." checks the "Selected Tracks Only" box in the dialog for you, but really, they're the same thing if you set all parameters in the export dialog the same.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 07-16-2023, 09:05 AM
BLUElight AudioMedia BLUElight AudioMedia is offline
I think people in this thread are confusing the menu item "Export.." with the "Export Selected" shortcut Command+Shift+K, which are two different things.
The menu item just takes you to "Save Copy In" if you choose to export as a session.
The shortcut will just export the selected clips and nothing else.
Old 07-16-2023, 10:25 AM
lesbrunn's Avatar
Yes.
Thanks. That is something I know more or less, but I'm asking because I haven't really RTFM
Old 07-16-2023, 10:28 AM
lesbrunn's Avatar
Thanks for that. Whereas 'Copy In' would include everything...
Old 07-16-2023, 10:37 AM
lesbrunn's Avatar
So "Export Selected as Session" is essentially the same as "Save Copy In"? Of course, one would need to select everything for the two to be the same.
Old 07-16-2023, 11:24 AM
I don't see anyone confusing those. We're all talking about the file menu command. Except I think Janne might have been thinking of Bounce.
~Will
1) "Save Copy In" command does NOT make a complete copy! 2) How to properly backup XNA Pro Tools 2018 18 05-28-2019 03:52 PM
Save Session Copy doesn't copy all files within the bin anymore Farhoof Pro Tools 12 13 11-27-2015 09:11 AM
SAVE COPY IN bounce file nor .mov copy saved ronjohn333 Pro Tools 11 1 10-01-2015 12:46 AM
"Save Session Copy in" occasionally doesn't copy.. Willard Pro Tools TDM Systems (Mac) 0 03-06-2007 12:31 AM
save sesssion copy x copy folder to another HD Alécio Costa Pro Tools TDM Systems (Mac) 6 10-22-2002 09:29 AM
