Old 03-31-2018, 12:46 PM
Sir Hannes Sir Hannes is offline
Default Re: set automation to off/touch (shortcut)
Understand, I had that "current ... type" also in mind. I just did not get the point as there's no "paste pan automation" in the menu (or eucon). Or did they changed in 2018? (I am on 12.5)
MBP Late 2013 OSX Sierra
ProTools 12.5
EuControl 3.7
LogicPro9
Old 03-31-2018, 01:10 PM
BScout BScout is offline
No. They did not change it.
"Paste" is paste. It takes whatever automation lane you copied and pastes it into the exact same automation lane type. So Pan = Pan. Volume = Volume. etc. For instance: you could copy volume automation to the same volume lane on another track.
"Paste to current automation type" takes one automation type and pastes it to a different automation type. Say you want to copy the automation you did on volume to the send automation lane. Or you want to copy the volume automation to a plugin's parameters (that you have enabled automation on.) If you did a normal paste it will not work. If you do a "paste to current automation type" it will paste the same automation to the send automation lane (if you have that lane open and selected.) Or say you want to do something wacky and have the volume jump up every single time you pan to the left. You can copy the pan automation to the volume lane.
How to read/touch Automation while recording? Rockman413 Pro Tools 10 7 05-13-2012 09:29 PM
Bad behavior of Touch automation Mode bortraws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-01-2008 04:38 AM
Automation overwrites data even if you do not touch anything Ale Pro Tools TDM Systems (Mac) 4 05-27-2007 06:05 PM
plug-in automation an touch-mode jimlongo ProControl, Control|24, Command|8 4 06-22-2005 09:36 PM
C24 Touch Automation Bug autopilot ICON & C|24 0 04-10-2005 08:29 PM
