Midi not working with Digi 003 rack after OS update
I am having some trouble with my midi and wondered if anyone could offer any solutions. I've spent a good while searching the internet for a fix but can't find anything that has helped me up to now. Basically, I have my 003 rack running with either pro tools 10 or logic 9 when composing music. I've had it working fine for a good few months whilst I was working on a film score and I decided to update my OS yesterday having finally finished all my work. But now neither logic or pro tools will recognise my keyboard that is connected to the midi port on the 003. The green midi light is on plus the green host light but there is no response from either DAW when I play any notes. I did have the same problem about a month ago when I upgraded my pro tools from 8 to 10 but all I needed to do then was download the right 003 drivers and everything was working again. But since I updated my OS from snow leopard to mountain lion yesterday the midi problem is back. Each DAW recognises midi through USB such as my fader controller and my drum pads but nothing that is connected via midi ports on my 003. Like I said I've spent ages now trying to find the right solution but have had no luck so thought I'd try posting this to see if anyone can help. Thanks Simon |
Re: Midi not working with Digi 003 rack after OS update
Have you reset things in the Midi Studio page? I'm on PC so it may be different, but for me, in Pro Tools, go to Setup>Midi>Midi Studio and create an "instrument"(whatever midi controller you have) and set the ports for midi in (and OUT if needed). Without this setup, PT simply doesn't know where to expect midi information to come from
Check the avid comparability charts... I've had similar issues and had to downgrade my OS to play nicely with pro tools. I'm now running 10.3.10 and 10.8.5 (PT and OS respectively) with my 003r and no issues.
Thanks for the replies. I've just got back to my studio after a couple of days away, turned everything on to try those suggestions and my midi worked fine before I even tried anything. I literally haven't touched anything since my initial post so I can't explain it but it's all working fine now. Very strange but thanks for the replies anyway guys :)
Did you also update the driver?
Digi 003 Rack Update | samcharles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-25-2011 05:40 PM |
Digi 002 Rack Ch 2 & 4 not working... | JLEpperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-02-2010 04:04 PM |
Digi 002 Rack not working!!! | x12bitgodx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-25-2006 11:24 AM |
I Can't update digi 002 rack firmware please help! | Escape | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-18-2004 09:11 AM |
Digi 002 Firmware Update not working... help? | Mt.Everest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-16-2003 11:18 PM |
