Old 05-01-2013, 06:53 AM
mlemos mlemos is offline
Default Artist Mix SEL button doesn't work
hi,
my new artist mix's SEL button does nothing. the only way i can select a track is through PT.
is this a programming defect or do i have a faulty unit?
BTW, it didn't work with eucon 2.7 and it doesn't work with 2.7.1
thanks,
marco
Old 05-01-2013, 02:52 PM
Default Re: Artist Mix SEL button doesn't work
can anyone let me know if they are able to select a track using the SEL button on the artist mix.
even a simple yes or no would be helpful.
marco
Old 05-03-2013, 05:55 AM
okay...can someone from avid chime in and let me know if the SEL buttons actually work. please.
thanks,
marco
Old 05-03-2013, 09:13 AM
Halfmoon Halfmoon is offline
Marco,
SEL key is working here on my MC Mix w/ PT.
Does anything else work from your Artist Mix - faders, banking, or the Shift-layer Transport commands, Solo/Mute(On)?
Here are instrux for running the unit in Test mode (one way to check that faders and switches have basic functionality):
To access Test mode for Faders and Switches:
1. Make sure the unit is powered off.
2. Hold <PAGE+PAGE>+NUDGE>+the left SHIFT key while pressing POWER to power the unit on. The faders begin to travel from lowest to highest positions and back. LEDs flash on/off. You can press any switch to see its name on the channel displays.
Let us know if any of the other Mix functions are working w/ PT, and if any SEL switches appear unresponsive in Test mode. MIght be a defective unit, but it could be something else (the whole unit or some of it might be "locked" to a different application - EuControl Settings > Assign page).
M
Old 05-03-2013, 10:46 AM
M,
thanks allot for the reply.
yes, all other functions are working just fine.
when i try to enter test mode the only thing that happens is the first channel strip says 'Use DHCP yes (default). no fader movements. pressing the select switch does toggle DHCP to 'no' but i'm not sure what to make of that.
i'm really starting to think that the unit is defective. i've gotten in touch with sweetwater and a tech is going to contact me. if it's defective they'll send me a new one.
thanks again. really appreciate it.
regards,
marco
Old 05-03-2013, 11:21 AM
i guess that the key combination for running test mode has changed.
i found it here: http://euphonix.avid.com/artist/ux/e....php?detail=27
the select switches work fine in test mode but don't work at all when not in test mode. i opened several sessions and nothing.
i also ran auto test mode and everything seemed fine.
i'm waiting to be contacted by a sweetwater protools tech and hopefully they'll get to the bottom of it or ship me a new unit.
marco
Old 05-03-2013, 01:20 PM
never mind...user error. i spoke with sweetwater and they informed me that i have to use the select button next to each fader, not the select button above each fader. i din't even realize that there were multiple select buttons.
regards,
marco
Old 05-03-2013, 01:52 PM
I think I made the same thing when I first started using my Mix!
For a relatively brief intro to using Artist series controllers w/ PT, check out the PDF called Artist Series and Pro Tools. It's installed w/ other Pro Tools Documentation. The one installed by PT 10 is newer than the one installed with EUCON (look for "Version 10" on the front page/cover).
Glad your unit turned out to be fine.
M
Artist Control & Mix do not work with PT 11.1 Franklyn Artist Series 3 01-10-2014 10:03 PM
Artist Mix doesn't work in PT 11 redroomsound Artist Series 1 06-25-2013 03:44 PM
Help!! Can't get Avid Artist Mix to work Mischdepp Artist Series 5 04-25-2013 02:25 PM
Play button won't work? SmackUranus Pro Tools SE and Essential (Mac) 1 08-13-2012 06:09 PM
Sometimes play button doesn't work tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-26-2007 09:20 AM
