Old 11-13-2011, 11:48 AM
san san is offline
Default Eleven Rack crash
Hi people !
here is my problem.
I ve just got my 11R, the first switch on was fail because I had no sound in standalone mode .
I solved It with a reset !! Good ..
Now, when I plug the 11r to my laptop .(windows 7 64 bits)
the 11r suddenly crashes, that means , after a small clik : no sound anymore, no signal, even in the tuner .
After that I have to reset it to make it works again in standalone mode.
So I ve tried with a mac book pro, no problem everything s working, i v tried with a windows xp, the same no problem.
Does anyone could help ..
thanks a lot !
Old 11-13-2011, 12:47 PM
Chris Townsend Chris Townsend is offline
Default Re: Eleven Rack crash
I suspect you might have a bad unit. I would look at exchanging it, since you just bought it.
Chris Townsend
Guitar Products Architect
Digidesign, A Division of Avid, Inc.
Old 11-13-2011, 01:26 PM
san san is offline
Thx Chris ,
I will return the unit so!
I hope for the last time !
Thank you for your answer .
Eleven Rack / Avid is not producing anymore Eleven Racks is that true or false? Rongpat Eleven Rack 8 02-11-2014 07:42 AM
Some experimental tracks using Eleven rack and Eleven RTAS kittybite Eleven Rack 4 06-18-2013 12:18 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
Can't install eleven rack expansio (crash) DanielVE Eleven Rack 4 12-06-2011 02:20 PM
