Old 04-01-2010, 09:35 AM
Maximo Maximo is offline
Default Midi recording issue
I am using a HP Notebook running winXP.
I've been recording this way fine for 3 years to a mybook external HD.
However, I want to start using Reason Adapted though my PT and record midi.
I have it all set up properly and my controller is working fine.
The issue is recording.
It will not record for more then 5 seconds ever. It just seems to not register the data after like 5 sec.
It is still recording as if it was, but no sounds are recorded after the initial 5 sec. rendering my midi set up useless
HP notebook
winXP recording to a mybook ext HD
Recording through a mbox2 and using PT 7.0
Never had any recording issues previously with audio.
Anyone else ever have this issue?
Any setting I should look at?
Thanks.
Audio and midi recording issue djcreation24 Windows 11 02-03-2014 04:33 PM
MIDI Issue when recording and play back in PT8 LE musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 24 09-23-2009 07:14 AM
Recording Plugin Automation with a Midi Controller Issue realitypoint Pro Tools M-Powered (Win) 9 05-16-2007 06:20 PM
Mbox2 Midi issue - Recording but not triggering jpaz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-07-2006 01:47 PM
Timing issue when recording audio from MIDI tracks Gothboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-16-2006 07:42 AM
