volume automation on Xpand
I cannot seem to get the automation to stick on this, wherever the fader is last left... that's where it's stays, despite the pencil tool allowing me to draw it in
do I need to bounce to another track to do this (seems archaic) I've tried both the master fader and the volume level/fader within Xpand
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
Re: volume automation on Xpand
Plug-In Automation or Continues Controller Automation?
Aaron Mulqueen - 001 HD Native |
automation after the fact- I change the edit view to volume, select the pencil, make my adjustments, hit save... aqnd the volume is wherever it was last left (in this case a fade to silence)
I select write, and move the channel fader where I want the changes, hit stop, save... same resxult as above I grab the fader in the plug-in (Xpand), hit write, go through the track, making the changes, save... still no luck
Automation Enable Window - Plug-In enabled?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
I have pulled every element over to the automate window
I've seleceted Audio volume... drawn chaos with the the pencil... the line holds in the volume window... but the fader/level remains unchanged no automation I've tried structure and Xpand same results seems I can get individual tracks (1 of the 4) to work... but i can't get a "global" change maybe that's the work around? select all 4 tracks and draw the fade?
It sounds like that's what you want to do, but maybe I'm not getting what you're saying.
And one more thought. You said the line holds in the volume window, but the fader remains unchanged. I think you mean that whatever you drew remains? If so, what you didn't say was what effect you heard...that is to say, did what you drew actually affect the output? If so, then your automation did affect the output even if you don't see anything going up and down on the screen.
Converting Volume Automation to Clip Gain = Higher Volume! | EricWillhelm | Pro Tools 10 | 8 | 11-01-2011 11:12 AM |
Xpand! 2 dramatic volume drops | aaronmolnar | Virtual Instruments | 10 | 06-02-2009 01:07 PM |
Xpand and frozen volume sliders | digitalpan | Virtual Instruments | 6 | 02-10-2007 11:32 AM |
Xpand not playing automation.....??? Help... | Tympanic | Virtual Instruments | 0 | 03-22-2006 06:01 PM |
