Old 02-06-2010, 05:24 PM
Bob-E-Digital Bob-E-Digital is offline
Exclamation AKAI MPK25 in PT8
I have gone through the different threads about using the MPK in ProTools8, I am yet to get my MPK 25 to be recognized by PT 8, I have downloaded the CS-10 template, I have followed the steps provided in the post and still NOTHING, can anyone please help, the keyboard works fine in my other software, Arturia, Reason, but it will NOT be recognized by PT, VERY FRUSTRATING!
Old 02-08-2010, 08:21 PM
Default Re: AKAI MPK25 in PT8
ANYONE has any suggestions....................................... .........I am still waiting on AKAI technical support to get back to me.
Old 02-10-2010, 07:50 AM
Thumbs up Re: AKAI MPK25 in PT8
Bump
Old 02-16-2010, 06:36 PM
UPDATE:
I can get the keyboard to work only when recording, but i CANNOT hear the midi notes while recording, only during PLAYBACK after recording, I have looked at INPUT MONITORING but still nothing, any suggestions
Old 02-16-2010, 06:43 PM
1. To set up the MPK25 in Pro Tools to trigger instrument or midi tracks there are
just a few steps to follow. First you must create an instrument or midi track within the
software. To do this go to Track>New and choose to create a new Instrument or Midi
Track.
2. Now from within the Edit Window you will see the instrument track but nothing is yet
assigned to it and there isn’t any apparent way to set an input or output. To make this
possible you must go to View> Edit Window and make sure there is a check next to
Instruments. This can also be done for the Mix Window.
3. Now we must choose the midi input so the device can be routed to this track. Now
usually if the device is connected and recognized before starting Pro Tools all 3 inputs
will be chosen automatically.
For the MPK25 you will see MPK25, MPK25 (2), and MPK25 (3). Sometimes
they will appear as their driver, USB Audio Device, USB Audio Device (2), and USB
Audio Device (3).
To do this go to Setup>Midi>Input Devices
4. After this is done you will have everything configured to start setting up different
instruments. To choose an instrument for the track you must first choose the midi input
for this track.
5. From here you must choose the first MPK25, or USB Audio Device input on All
Channels.
6. Now you must choose what plug-in you will be triggering via the Insert Menu to the right
of your instrument options. Click one of the arrows to drop down your options and go to
plug-in>Instrument to see a list of available plug-ins.
7. Next choose the midi output, or the instrument you will be using. To do this you click on
the Output Selector on the same track you chose the input and simply choose the plugin
instrument you would like to trigger.
You should be all set. Also, be sure to record enable the track before recording.
Old 04-06-2010, 03:34 AM
sktsage sktsage is offline
I've been looking into buying one of this.. Could you let me know if everything on the keyboard works with pro tools?
Thanks,
Pulling samples with Pro Tools 11 and MPK25? bretmanley General Discussion 1 02-21-2014 10:36 AM
Akai MPK25 MIDI Keyboard Set Up thebass Getting Started 2 06-19-2013 01:11 AM
Transport on MPK25 anytimesoon MIDI 0 05-23-2012 01:03 PM
PT 10 - eleven rack - akai mpk25 and midi out st41p9mike MIDI 3 01-04-2012 02:41 PM
MPK25 with PT9 keoni MIDI 0 06-13-2011 08:55 PM
