Automation overwrites data even if you do not touch anything
Sometimes it could happen that if I am in touch mode PT starts recording data even if I did not touch any faders.
For example from a preroll. So everything will be overwritten and is deleted. I have a command 8. Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1) 1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+ |
Re: Automation overwrites data even if you do not touch anything
I'm having this problem in a much more insidious way - Writing volume automation is almost invariably writing also to an adjacent track - It just happened now where I was writing volume to a VCA - and it also wrote new volume to the first track in the VCA group, rendering it useless.
This is now becoming so commonplace that I often have to have the adjacent track in SAFE mode to stop it . Needless to say - IT IS A PROBLEM DIGI - any explanations !!!!??? I'm running OSX HD tons of ram and plugs in surround with a command8 too. |
I've taken some advice and will test out removing the command8 from the equation.
I'm not that convinced tho - as I just had the same problem as you Ale in that a track/channel just spontaneously went into write that wasn't on the Command8 surface. Sheesh - if I managed to catch that one - imagine how many I've missed - no wonder I'm losing confidence in the mix I'm hearing ... Chur - Brent |
Wooh - thanks for that ...
Sorry - didn't see your post before posting my last one ...... Chur - b |
How to read/touch Automation while recording? | Rockman413 | Pro Tools 10 | 7 | 05-13-2012 09:29 PM |
imported session data overwrites current automation!? | yazoo | Post - Surround - Video | 2 | 02-19-2008 03:53 PM |
Fader #1 overwrites automation on fader #2 | Headmxr | ProControl, Control|24, Command|8 | 2 | 11-18-2005 05:46 PM |
C24 Touch Automation Bug | autopilot | ICON & C|24 | 0 | 04-10-2005 08:29 PM |
Converting MIDI volume data to automation data? | Duff Studios | Pro Tools TDM Systems (Mac) | 2 | 12-17-2002 09:39 AM |
