digitest fail
Hi all
I just bought a refurbed HD Process card for my HD Accel system with Apogee Rosetta 200 Connected it up and ran the digitest It fails on the Core card with "peripheral digital loopback test - channel 1: pattern (42) notstarted. (Failed 4 times) " This is listed 16 times The other 2 cards passed fine Is this error because the Apogee is the only peripheral attached? Protools seems run fine otherwise... Plays, records, TDM plugins are loaded onto all 3 cards, etc The only other thing strange is that my HD card order seems to be backwards from the instructions that came with the Process card My system: - AGP video card - empty - HD Core - HD Accel - HD Process - Video capture The instructions seems to list: - AGP Video card - HD Process - HD Accel - HD Core Any help appreciated Thanks! |
Re: digitest fail
do you have an interface plugged into the core card?
i'm not a digitest expert, but i think that's what it's complaining about. i believe i get this error the interfaces aren't turned on. jeff |
Re: digitest fail
If I'm not mistaken, you will get this error if no interface is attached or turned on, or the interface isn't made by Digidesign. You may want to contact Apogee to confirm that, however.
Re: digitest fail
Hi
Thanks to both of you Yes, the interface connected to the Core card is the Apogee and it was turned on I'll confirm with Apogee that this is expected behavior Until I hear back, I'll assume everything is cool Thanks! |
PT 10 MIDI fail | notedmusic | Windows | 1 | 03-24-2013 09:55 PM |
PT 10 over LE, install fail, ASC fail | JaeBe | Pro Tools 10 | 11 | 11-30-2011 02:29 PM |
All 4 Mix cards fail Digitest, but system works. Help..!? | innerbooty | Digidesign Hardware & Software | 2 | 03-28-2011 12:35 PM |
Digitest sometime pass sometimes fail | Joel Cage | Pro Tools TDM Systems (Mac) | 1 | 04-17-2006 12:59 PM |
Help Digi , or anyone , all cards fail DigiTest | acorredor | Pro Tools TDM Systems (Mac) | 4 | 02-21-2003 02:32 PM |
