#111
Re: Clip FX GUI not responding
Good riddance! So are you going back to 23.3?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins |
#112
Not yet - to help with the testing support graciously gave me a year's support plan. There's nothing I need in 23.3 or 6 and I see there's a lot of issues with 6 so I'm going to wait for the next reported stable release.
I also have a feeling (could be wrong) they're looking at that Windows installer which is definitely poor, there's whole massive areas it doesn't uninstall. The whole thing has made me generally a bit more wary of uninstalling and installing, so will only do it when there's a real benefit.
Guy Rowland www.guyrowland.co.uk www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music. PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i Macbook Air M2; 24gb RAM |
#113
#114
I installed 2022.12 last night on W10 and experienced the Clip FX bug right off with a single monitor setup.
Selected a clip and tried clicking on the GUI with no response. After I toggled to mix view & back I was able to see the changes. Reopening the session helped. Then I opened a different session and it happened again. I've experienced it 4 times so far after opening a couple different sessions but don't know an exact way to repro. Just confirming that it happens on a single monitor setup.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 08-11-2023 at 08:40 AM. |
#115
Interesting, thanks take77 - if you can bear it, let support know.
Being as lesbrun and I both made ours go away by taking it down to one monitor and back again, I don't quite know what to suggest in your case... plug in another, run PT, then go back to one?
#116
Yes, support has been very helpful and a case has been created.
So far it's only happened when selecting clips on a mono track. But I just installed 2022.12 and it may happen on stereo clips too. I was thinking of you guys after I installed and thought I'd do a few quick tests. I don't think mono as opposed to stereo clips would have anything to do with it and might just be coincidence. But hopefully a good lead. My main thought is that my system has integrated Intel graphics as opposed to a dedicated one. Not sure if that's the right terminology. But things work fine in 2022.7. Graphics drivers are kept update with the Intel driver & support assistant.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 08-12-2023 at 12:55 AM. |
#117
Still not come back here though since I changed the number of monitors and back again, hurray. The cure every bit as inexplicable as the bug.
#118
#119
Thanks for confirming it's happens on dedicated graphics & stereo clips.
I opened a session with stereo clips that worked fine last night and the bug happened right off. Thanks for the tip on resizing the window. Minimizing and maximizing the window solves the problem for the session. The GUI freeze happens as soon as I open a session so maybe I can train myself to quickly minimize & maximize the edit window after opening the Clip FX tab and before clicking on the GUI.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 08-14-2023 at 08:10 AM. |
#120
Here's a couple things I noticed just before the bug occurs on my system:
1. When opening the Clip FX tab the processor order is changed to Filters first. 2. If I hover over a filter type my cursor turns into a up/down blue arrow (only in the filter section). This lets me know things are not going to respond. Then after doing the min/max window workaround the GUI goes back to the default processor order. Quote:
Band Name or track title for sure.
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory Last edited by take77; 08-15-2023 at 01:13 AM. |
Randomly can't select single audio clip on timeline - Clip then disappears (2022.9) | take77 | Pro Tools | 5 | 10-14-2022 06:15 PM |
Selecting a clip in Edit window fails to select clip in Clip List | oldskool | Pro Tools 2020 | 8 | 09-28-2021 01:43 AM |
Nudging a clip past another clip removes the stationary clip | evil.beasts | Pro Tools TDM Systems (Mac) | 0 | 11-01-2017 11:08 AM |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | AAX Plug-ins | 2 | 06-21-2017 11:29 AM |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | Pro Tools 11 | 1 | 03-04-2017 12:35 PM |
