Upgrade issues (8.0.3cs2 with 10.6.3)
I've done extensive searching but not found anything that solves my issue.... I just upgraded to Snow Leopard 10.6.3, and PTLE 8.0.3cs2. Pro tools works fine, however any third party or system applications such as iTunes cannot use the core audio manager. In fact, the core audio manager will not launch at all. Whenever I try to open it as standalone or by selecting my 002r in system preferences I get the following message: "Digi CoreAudio Manager cannot be opened because of a problem. Check with the developer to make sure Digi Coreaudio Manager works with this version of Mac OS X. You may need to reinstall the application. Be sure to install any available updates for the application and MAX OS X. " I've tried uninstalling and reinstalling, but I still can't get CAM to launch without this error message....weird thing is that PT is working fine! Thanks for any help or suggestions! Adib |
Re: Upgrade issues (8.0.3cs2 with 10.6.3)
Pro Tools is not supported in 10.6.3. My guess is that CAM is not either.
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
Hi, I realise that PT isn't supported, however it does work (maybe some bugs that I'm not aware of). The issue is with CAM, and I've seen/heard reports of it working....I just can't get it to! Just wondered if anyone has come across and worked around the issue I'm having......
I had the same problem. Here is my workaround - Do search in spotlight for CoreAudio Manager - Move it to e.g. the Desktop - In the sound settings select your digi device e.g. Digidesign MBOX Mini This worked for me. It seems like the Core Audiomanager doesnt work in 10.6.3. When I launched it manually it launched but didnt find any devices. |
Funny thing is that CAM did not work for me until I installed Snow Leopard, and it still works now at 10.6.3.. Basically, don't assume anything as far as CAM functionality is concerned... There are some specific CAM troubleshooting steps that DTS has recommended in the past, but I don't remember them, sorry... They include deleting a couple plist files etc.. Try searching around in the forum. If I come across it I'll post the link.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
If anyone has any suggestions let me know - I'm at a bit of a loss here! Thanks |
Upgrade Issues - Help Please | rkaynan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-08-2011 01:45 PM |
8.0.3cs2 update - issues continue | bornheim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-09-2010 08:50 PM |
8.0.3cs2 bugs/issues continue on ... | bornheim | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-08-2010 07:52 AM |
Audio sticking + can't upgrade to 8.0.3cs2, says PT not installed | alphabet73 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-06-2010 12:32 PM |
considering CPU upgrade; any known issues... | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-26-2003 09:00 PM |
