Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 01-17-2015, 08:17 AM
nst7 nst7 is offline
Default Re: Focusrite Scarlet 18i20
Yes, that's pretty much it. And also the Scarlett has Word Clock out, in place of where the second firewire port would be on the Saffire 40.
Focusrite have stated that these are basically identical units. They came out with equivalent USB units because how computers were evolving. In the case of Windows PC's, firewire was always very iffy, and you had to have just the right firewire card, etc. With Macs, they started dropping the firewire ports altogether. So Focusrite came out with these USB units as an alternative for people to not have to use adapters and such.
However, they do advertise that if you use the the Saffire range, they will work fine with the Apple Thunderbolt adapter.
Also, they have stated that the Saffire firewire units are a little bit lower latency at the equivalent buffer of the USB units.
Old 01-17-2015, 08:38 AM
Michael Zull Michael Zull is offline
FWIW, I have a Scarlette 2i2 that I have used with W7, W8, and Mac OSX 10.9.x systems, on PT 10.3.9 and 11.2.1, and it's never given me any problems that I can recall.
Old 01-18-2015, 07:38 AM
tchipman tchipman is offline
I'm so glad I came back here to visit. You guys have given me so much great information.......I really appreciate it. It also makes me feel a little secure having katherine from Focusrite watching. Now I have to decide which one will work for me........the 40 or the 18i20?
More a little later........I really need to pick your brains!
Tim
Old 01-19-2015, 07:16 PM
DonaldM's Avatar
DonaldM DonaldM is offline
Tim
Let us know what you decide!!! Also, I'm not sure Katherine is still around, but there is someone else from Focusrite that checks here.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 01-20-2015, 10:22 AM
Hi Donald........I've looked through your list of equipment....very impressive. What I'd really like to do is start over with some kind of Thunderbolt interface and PT 11 and go the 64 bit direction but I can't afford it for one thing and another I'm not sure even if I could that it would make me enjoy what I'm doing in the basement any more.
I'd have to start over with plugins (not good....I've got a bunch of the Waves stuff that I like)......so that's why the Focusrite interface looked like an attractive alternative to the Digi 002.
I wrote Katerine a private message but you said she was gone. Who do you suggest I visit with at Focusrite?
Tim
  #16
Old 01-20-2015, 11:03 AM
One other question...........is that your Dragon Rock Productions on SoundCloud? (Donnie Allen)?
  #17
Old 01-23-2015, 01:50 PM
Christian.Focusrite's Avatar
Christian.Focusrite Christian.Focusrite is offline
Focusrite
Hi Tchipman,
You can PM me anytime. I try to check my inbox as frequently as possible. Also check out what we just announced:
http://us.focusrite.com/clarett-range
Thunderbolt range!
  #18
Old 01-26-2015, 09:46 PM
DonaldM's Avatar
Yes
Pro Tools 2018.12
  #19
Old 04-11-2015, 03:58 PM
mattskii mattskii is offline
Hi.
Only just had my attention drawn to this.
I’ve got a Scarlett 18i20 interface. However, it’s not stable on PT11 in that -6001 errors occur when moving between sessions of different bit rates. This might be an issue related to W7 or USB2, but I’m still not sure as the Focusrite help wasn't very helpful.
I eventually concluded that the cause was with the Focusrite drivers. The earlier version confines me to a 44.1. I can get above that with the current version (in scarlett-mixcontrol-1.8), but - as I've said - it's unstable. Their beta (in Scarlett MixControl-1.9b4) is dangerous. When it fails you need to do a complete deinstall of PT to make things work again.
The interface is, however, stable with PT10. It's also stable with Reaper.
Cheers,
Matthew.
  #20
Old 04-14-2015, 11:13 AM
Re headphones, any interface that has 4 or more outputs is a prime candidate for a decent headphone amp. The one I use is the Alesis Multimix 6 Cue. How you feed it depends on your needs. At first(with my 003) I fed the main outs to the Alesis main inputs(everybody gets the same basic mix) and then used other outputs fed by AUX sends, so each of 4 players could have "more me"(had to make special cables, but anyone that can solder can do this). Now I feed 5 stereo mixes out of my HD IO so I can give separate mixes to all 5 players(about all I can fit in my little cave) ART makes a similar unit that has the AUX inputs on the back, so that might be a better option(but its another $50).
Focusrite 18i20 Disconnecting with Pro Tools 11 SuperDave71 Third Party Interfaces 4 06-20-2014 06:43 AM
Focusrite 18i20 won't power on. Woodybear Third Party Interfaces 3 04-03-2014 04:19 PM
Focusrite 18i20 MEWCO Third Party Interfaces 17 03-03-2014 09:37 PM
Mbox Micro with PT 8 LE + Focusrite Scarlet 2i2 elmodagansta Windows 2 02-08-2013 02:57 AM
transfuser with protools 9 and focusrite scarlet 8i/6 zela8 Virtual Instruments 0 10-16-2011 10:27 PM
