Old 01-21-2010, 04:20 PM
studiojimi's Avatar
studiojimi studiojimi is offline
Default drum replacement / augmentation options
i have been trying drumagog for the past two days
it seems to do the things i'm looking for
sure works more accurately than sound replacer
i see they have 3 prices for different levels of uses
i'm pretty sure i need the basic version although i have the pro...not platinum version installed as a demo
my buddy says to check out toontracks...and that appeared to be more midi oriented than what i'm looking to do
i'm asking you guys what you use and why
is drumagog the preferred replacement/augmentation tool?
CAZADOR RECORDING
PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2
With GOD as my partner. . . I need to make my plans LARGER.
Old 01-21-2010, 06:31 PM
BradLyons BradLyons is offline
Default Re: drum replacement / augmentation options
I have DRUM REHAB but have well....I'll just bite my tongue, it's good but has it's issues. I think what you're trying out is really your most ideal solution.
Thank you, Brad Lyons
GC PRO- Pro Accounts Manager
(404)844-9758
blyons@gcpro.com
www.theaudioprofessional.com
Old 01-21-2010, 06:50 PM
Phil Buckle Phil Buckle is offline
At the moment there is a video tutorial on the Toontracks site that shows the method of using their product. It's quite a detailed method if you want to dig that deep.
On the other hand if you search the DUC you will find a great post by Kingfish where he demonstrates the simplicity and speed of the Massey DTM plug.
I have Drumagog but never used it after seeing David's video.
HD Accel 2, Magma PER64-I
Mac Pro 2x3.2 Quad Core/OSX 10.6.8/VEPro/PT9.03
http://philbuckle.com/
Old 01-21-2010, 09:57 PM
elicious elicious is offline
hey sj , you might want "hold fast" just a bit longer for this!
b.o.l.
e
(although on the gui "sensitivity" is still misspelled!
ihatetyping
Old 01-21-2010, 11:25 PM
c-tone c-tone is offline
Drumagog 5 is due out in April, if you can wait that long. It looks like it has some real improvements, most notably the sample accuracy.
www.clifnorrell.com
Old 01-21-2010, 11:35 PM
EvilElfBoy EvilElfBoy is offline
I use Drumagog and DTM. Pretty much all you need. Drumagog does quick sample replacement, while DTM triggers any sampler for the sample you have loaded. They both work awesome. I don't use PT anymore for mixing, so watch that sample latency when using Drumagog in PT.
AKA - EvilElfHobo
Pro Tools 10 HD Native | Mbox 3 Pro | MacBook Pro 2.3 i5 | OSX 10.7.4
Pro Tools Music & Post Operator V6-8, Instructor, and Expert ICON Mixer Certified.
Multi-Platinum Pro Tools Videos
Old 01-21-2010, 11:48 PM
Dizzi45Z Dizzi45Z is offline
I have Drumagog but I always run into phase problems with the Kick drum to the point where I either use Drumagog at 100% or I use my raw Kick track. Trying to blend them becomes a nightmare. I can hardly wait to try out Trigger. It seems like it will be available first. I'm sure the new Drumagog (5) will be good too, but I think Trigger will come with Stephen Slate samples which are far superior to Drumagog's current sample library.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools 12.8.3 HDX Mac OS 10.12.6
Mac Pro Quad 3.2 Nehalem with 32 GB RAM
Noisebox Studios -Utah Recording Studio
Old 01-22-2010, 01:02 AM
midnightrambler midnightrambler is offline
I still do it manually! What a luddite eh.
Old 01-22-2010, 02:04 AM
crizdee's Avatar
crizdee crizdee is offline
Drumagog just isn't accurate enough. its hit and miss where it lands, sometimes early sometimes late and occasionally on the button.
Rehab is accurate, but mono only and a terrible browser, but gets the job done.
DTM if you have it!! then use your favorite midi playback plugin.
don't know about the others
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 01-22-2010, 04:49 AM
pmklein pmklein is offline
Here is what I have learned- Drum Rehab is very good if you learn how to tweak it correctly. But, it doesn't do stereo samples. So, you have to use Drummagog for that. The two in combination can create amazing results. I've seen someone who is adept at this (he's on the DUC) arrive at fantastic drum sound overhauls.
001/v6.4 Life Support / Replacement Options bobe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-29-2012 11:04 AM
003 Best Options For Replacement. philip888 Pro Tools 9 3 11-03-2011 10:58 AM
003 Best Options For Replacement. philip888 Pro Tools 10 18 11-01-2011 12:47 PM
Replacement Options for Waves Plug-Ins... soundlife2 Pro Tools TDM Systems (Mac) 54 11-30-2005 09:39 AM
Drum Replacement vocalize Pro Tools TDM Systems (Mac) 9 09-20-2005 12:19 AM
