  #41
Old 12-03-2018, 07:39 PM
BScout BScout is offline
Default Re: Video Card - Mac Pro High Sierra & Native
Mine (and everyone who has a retail box) comes with power cables for the Mac and power cables for PC. When using the SATA power from the optical bay, you need the power cables for the PC plus an adapter to mate it to the SATA power supply.
  #42
Old 12-06-2018, 08:36 AM
the.engineer the.engineer is offline
Originally Posted by LDS View Post
Yeah, it seems like a bit of a minefield out there in this regard. Just to clarify, when you say you spliced into the PCIe AUX power for your HDX card, would using a simple 6-pin mini-PCIe Aux 'Y' cable achieve the same thing? I have a Mac Edition GTX 680 sitting here that uses 60w less power than your 280x, so the same solution should work fine.
Yes, same thing. I cut the mini 6-pin to large 6-pin in half, then using a pinout diagram and multimeter made sure I knew which pins on the four pin HDX connector needed 12V and gnd and soldered them all together again!
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #43
Old 02-03-2019, 10:56 AM
1m1 1m1 is offline
Originally Posted by off the wall View Post
I'm running the power for my HDX card off of one of the unused SATA ports on my 2010 Mac Pro.
See this post for details:
http://duc.avid.com/showpost.php?p=2491563&postcount=34
All of the SATA to 6 pin PCI-e cables that I've seen are 15 pins. Do you have to modify the plug to get it to work with the 22 pin SATA in the Mac Pro?
  #44
Old 02-03-2019, 12:07 PM
off the wall's Avatar
off the wall off the wall is offline
You have to trim off the locking tab on one side of the SATA connector.
File Type: jpg 74F427C4-2AEB-408B-A25F-E86775D26C87.jpg (23.9 KB, 0 views)
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #45
Old 02-03-2019, 12:18 PM
1m1 1m1 is offline
thanks! that's the answer I was looking for. Does the connector slide side-to-side without the locking tab, or does it sit securely in place without anything holding it there?
  #46
Old 02-03-2019, 01:14 PM
It does not slide side to side since the other tab is still there. I put a cable tie on mine so that it wouldn’t slide out since friction is the only thing holding it in.
File Type: jpeg 307794D7-1D21-4683-8F2D-9BE3800AB721.jpeg (80.7 KB, 0 views)
  #47
Old 02-03-2019, 02:26 PM
1m1 1m1 is offline
thank you!
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 1 05-11-2019 04:48 PM
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
High Sample rates with Native HD card Media Man Windows 6 02-27-2017 11:48 AM
HD Native card physically generates high pitch whine or squeal mlange Pro Tools HDX & HD Native Systems (Win) 6 03-15-2012 02:59 AM
