Gate Key timing variations
I use C1 Gate from waves and I dont know if I'm crazy but it seems my gate key is moving because of delay comp when I reload my project. Everything is fine and in sync, and then when I close and reload the project, the gate key timings are not correct anymore and I have to nudge the key track a bit. It's like the delay comp had some extra samples in the session and was remaking the compensation calculations when reloading.
Does anyone have experienced this issue? |
Re: Gate Key timing variations
I like using the Oxford gate for drum gating because it has a built in key trigger compensation (no shifting necessary). However in order to get it to work properly, after adding the Oxford gate you must close the session and reopen it in order for the compensation to work properly. This bug has been around as long as the Oxford.
Do some careful tests with the C1, to be sure. STeve
macmandigital.com |
On HDX rig, Dyn3 Expander/Gate timing is different (DSP vs. Native) | dave-G | Pro Tools HDX & HD Native Systems (Mac) | 4 | 11-17-2013 10:52 AM |
Variations in .wav files? | RaySoul | General Discussion | 0 | 04-27-2009 02:42 PM |
Guitar Part w/ Slight Variations In Tempo - HELP | Equality 7-2521 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-19-2006 07:48 AM |
Single Kick sample variations, Any tricks? | Glenn75 | Pro Tools TDM Systems (Mac) | 2 | 07-03-2005 09:41 PM |
Variations on a theme: Cannot create DAE deck | MorryC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-26-2003 06:05 AM |
