Old 03-19-2020, 08:08 AM
the.engineer the.engineer is offline
Default Hard Drive Choices in 2020
Hi Everyone,
Recently my Raid 0 array took a dump (2x 2TB 7200rpm Seagates) and freaked me out. I got it back working again after reseating the drives in the Mac Pro 5,1, so far so good.
Now Pro Tools is throwing -9073 errors all over the place even though my sessions are in the Disk Cache. I transferred a session across to my boot drive (see signature) and it works fine, no -9073 errors.
What's the next step? Replace the Raid 0 array with new spinners? Replace it with 2.5" SSDs? Or get anoyther PCIe M.2 board with more slots and run my sessions of a smaller NVMe drive?
Your advice is, as ever, greatly appreciated.
Best,
James
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 03-19-2020, 08:13 AM
arche3's Avatar
arche3 arche3 is offline
Default Re: Hard Drive Choices in 2020
Get 2 ssds put on the sleds. Plenty fast enough for protools. Don't need to raid 0 them.
Sent from my SM-G986U using Tapatalk
Old 03-19-2020, 08:20 AM
JFreak's Avatar
JFreak JFreak is offline
SSD into sled for boot drive and PCIe M.2 for audio/samples. As said, you can safely skip RAID altogether.
Janne
Old 03-19-2020, 02:40 PM
Just ordered a 2TB OWC for an audio drive. Should keep me going for now!
Thanks chaps.
James Welch
Old 03-19-2020, 04:50 PM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Why not NVMe for the system drive?
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 03-19-2020, 08:56 PM
JFreak's Avatar
System drive does not need to be the fastest. Some have reported issues with old cheesegraters if they only run PCIe storage (with sata bays empty) but cannot confirm as my mac pro is a trashcan
Janne
Old 03-20-2020, 05:39 AM
weezul weezul is offline
Booting and opening applications, the difference between SATA SSD and Nvme is negligible, almost the same. It's the increase in access time that helps boot time the most, having to grab lots of different files from the drive. But the difference between a spinner and SATA SSD is absolutely massive.
However, loading sample libraries the speed difference becomes more obvious and beneficial. Of course the trade off, is NVMe storage costs more. Personally, I have NVMe as boot drive, scratch disk for heavy data workloads, along with sample libraries I use on the daily (basically, pt instruments). Then I have a large SSD for samples I don't use as often (Kontakt Library etc), another SSD for current session projects, and then 4x HDD NAS for master backup of files. Don't forget your cloud backup!!!
MacBook Pro: 16GB M1 Pro 8c
Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580
Pro Tools Studio, RME RayDAT PCIe
http://www.liamgaughan.com
Old 03-20-2020, 05:43 AM
What NAS do you have?
James Welch
Old 03-20-2020, 05:55 AM
lesbrunn's Avatar
OK. I didn't realize the difference between NVMe and SSD was negligible for the system. I use NVMe for my boot drive and NVme/SSD for audio and samples.
Old 03-20-2020, 06:53 AM
bobcharest bobcharest is offline
I just replaced all spinners with SSD, and I agree, the speed difference is wonderful. One laptop that I just bought had 250 Gb NvME drive. I replaced it with a 1 Tb NvME drive. The NvME was just slightly higher priced than the 1Tb SSD drives I used, but is less expensive than, say, Samsung QVO 1Tb drives.
Great to have such inexpensive choices!
Best Regards,
Bob Charest
__________________________________________
Macbook Pro Ventura 13.6 Pro Tools 2023.6 Focusrite Clarett 4 Pre, 2018 Mac Mini Sonoma 14.4.1 Protools Studio 2024.3, X32-Rack & RME BabyFace Pro
New Avid Link 2020.1 - launched today 1/16/2020 marianna Licensing & Accounts 8 01-16-2020 11:43 PM
drive choices for virtual instruments TZaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-23-2009 11:22 AM
Drum recording: 3 room choices, 3 channels, 4 mic choices - pls lend your advice!! edgarbc1 Tips & Tricks 4 12-03-2009 08:40 AM
Usb Flash Drive Choices ? Anyone ? TommyT Pro Tools TDM Systems (Mac) 1 05-05-2007 02:11 PM
Hard Drive Choices mrguitarguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 10-27-2004 02:18 PM
