Old 10-27-2005, 08:28 PM
rantanplan rantanplan is offline
Default Mix Core vs. D24 + Mix Farm
I own a D24 card, a Mix Core card and two DSP Farm cards.
I'm wondering if it makes sense to sell the the Mix Core card and to buy a Mix Farm card.
The question is: Which system has more advantages? D24 + Mix Farm + 2 DSP Farms, or Mix Core + 2 DSP Farms? Has the "mixed" system D24/Mix exactly the same features as the genuine Mix system?
Please can somebody explain me the pros and cons?
Another question concerns the "Mix Engine": Is there always one Mix Engine running on a Mix system?
More precisely: On a Mix system, there's running a Mix Engine on the Core card. What about the D24/Mix Farm system? Is there also running a Mix Engine on the Mix Farm card? Or becomes the D24 Engine a Mix Engine?
Many thanks in advance
Old 10-28-2005, 04:53 AM
TCDet TCDet is offline
Default Re: Mix Core vs. D24 + Mix Farm
D-24 & Mix core = D-24 & Mix Farm
The only advantage is if you retire the D-24, your mix core will keep your system running.
If there is no DSP shortage than keep what you have.
If you need more DSP than sell the D-24 and add a MIX Farm.
All cards act as one system in TDM. (one engine)
Old 10-28-2005, 05:05 AM
Hi TCDet
Ah I wasn't thinking about this one (Mix core and D-24)... In that system would there also be taken one Mix DSP by the Mix Engine?
But what is the advantage to let the D-24 together wiht the Mix core? Why do two cores in one system make sense?
Does your answer also mean that Mix Core + 2 x DSP farm is less powerful than D24 + Mix Farm + 2 x DSP?
A lot of questions... I'm really a Mix newbie, I'm sorry for that
Old 10-28-2005, 08:01 AM
trakbytes trakbytes is offline
Are you running two systems, or do you need two systems? The D-24 card basically does nothing in a system that includes a Mix Core. You might be able to add more physical I/O with it in the system than is possible without, but I think we're talking about 4 interfaces or more.
If you're only running one system, then I'd say you should sell the D-24 with one or both DSP farms and see if you can pick up another Mix Farm. This will give you a Mix Plus, which will give you almost the same processing power as the current setup in half the card slots.
Bob
Save early and often! (or once a day whether you need to or not...)
Mix Core, DSP Farm QE, 6.4.1 TdM on 10.3.4 - Farm not shown Table Syrup Records Pro Tools TDM Systems (Mac) 2 06-18-2008 09:00 PM
Mix Farm WITHOUT Mix Core? SiliconAudioLabs Pro Tools TDM Systems (Mac) 3 04-21-2005 11:35 PM
mix core and dsp farm kiddyid General Discussion 4 10-29-2002 01:09 AM
D24/DSP farm v. Mix core poppy Pro Tools TDM Systems (Mac) 4 05-20-2002 01:36 AM
MIX Core, MIX Farm, DSP Farm & G4 933MHz Chief Technician Pro Tools TDM Systems (Mac) 6 04-25-2002 07:59 AM
