Old 03-27-2019, 02:30 PM
subhuffer subhuffer is offline
Default Set up 5.1 system with different size speakers
Hello
I am curious to see if it would be possible to set up a 5.1 system using two separate sizes speakers made by the same manufacturer?
I have a main pair of A7X and also a secondary pair of A3X. I would be looking to get a third A3X to complete the system.
I currently use an RME babyface pro but I was going to upgrade to the Apollo x6 that comes in 5.1 format. All the stores' technical support tell it is possible but of course, they want my money lol
Cheers
Old 03-27-2019, 02:50 PM
Default Re: Set up 5.1 system with different size speakers
Just connect it up and calibrate it. Calibration would classically be done in an outboard monitor controller, but that is built into the Apollo X. You need to read the Apollo X documentation, it is all there.
Hopefully you already know Pro Tools Ultimate is needed for built-in multichannel support.
Old 03-27-2019, 02:52 PM
thanks, I will check it out then. and yes, I am a Pro Tools Ultimate user.
Old 03-27-2019, 03:23 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Originally Posted by subhuffer View Post
Hello
Cheers
As much as possible, I would recommend your LCR being the same type of speaker. I had 3 JBL LSR4326 and 2 JBL LSR4328 and still decided to use the smaller set for the fronts. With that said, I know a 3" woofer compared to a 7" woofer is much more of a difference than a 6" to an 8".
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
HTML code is On
Can i connect my 5.1 speakers system on my Mbox 2 mini? Highnocent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-17-2007 01:15 AM
Controlling Overall Level to Speakers in a Quad/Surround System tcrist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-17-2002 01:24 PM
Does the size of the System drive matter? brasa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-10-2002 10:04 PM
Speaker stands for Genelec / Mackie size speakers tigeba Tips & Tricks 1 07-12-2001 10:54 AM
How to play CDs thru Digi System Speakers? AntGarg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-28-2000 12:45 AM
